Old 11-15-2011, 05:12 PM   #1
If I wanted to...
I just bought my first house and the first thing I started working on was the floor in the foyer and kitchen. My plan is to remove the old ceramic tile and all the underlay to get a clean start at the sub-floor.
In the foyer there was 2 layers of ceramic tile on top of 1 1/2" of motor or concrete before I reached the sub-floor. Now I would like to make the new tile flush with the hardwood flooring in the living room. The hardwood floor is 1 5/8" higher then the sub-floor.
My question is, if I wanted to "build up" the sub-floor so the new tile would be flush with the existing hardwood floor, where should I start? Just add some layers of plywood?
First picture shows the layers of tile and motor I went through, and the second is the difference between the sub-floor and the hardwood floor.
MRGierut013 is offline   Reply With Quote
Old 11-15-2011, 05:17 PM   #2
Tileguy
Bud Cline's Avatar
If I wanted to...
Try 3/4" plywood, then 1/2" tile backer board, then tile @ 3/8". See if that gets you where you want to be.
Old 11-15-2011, 06:30 PM   #3
If I wanted to...
When you say "tile backer board", do you mean something like cement board?
Old 11-15-2011, 07:03 PM   #4
Tileguy
Bud Cline's Avatar
If I wanted to...
Yup.
Old 11-15-2011, 08:15 PM   #5
If I wanted to...
Yup.
Great! Thanks a lot!
The Following User Says Thank You to MRGierut013 For This Useful Post:
Bud Cline (11-15-2011)
The Wife Wanted A Transom....Sooooo... DangerMouse Project Showcase 34 11-16-2010 02:46 PM
New here, wanted to say hello! Darien Introductions 1 06-15-2010 11:30 PM
Help: All I wanted to do was replace a light switch MicahPDX Electrical 5 07-04-2009 01:13 PM
I just wanted to say hi to everyone. Nestor_Kelebay Introductions 1 06-18-2008 03:12 PM
Wanted: Pergo Paradigm laminate flooring PG 7005 Ivory Sandstone ridgebluff General Discussion 6 05-30-2008 04:03 PM
