Identifying & Removing Adhesive From Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 01-06-2011, 12:41 PM   #1
I'm refinishing treads on a hardwood staircase and it's is giving me some unexpected problems.
The treads all have rubber non-skid mats on them. After I popped out all the nails that I *thought* were holding the mats in place, I found a thick layer of adhesive underneath.
The sheer volume of goop probably means I have to start with a scraper, but after that I'm stuck because I don't know what the stuff is - can it be sanded, does it need a solvent, what kind of solvent, etc. Are there any rules of thumb to make a reasonable guess?
If it helps, the adhesive is light tan. As I peel back the mat, the adhesive stretches and gets stringy. It turns whiter the farther it stretches.
gohanman is offline   Reply With Quote
Old 01-06-2011, 12:53 PM   #2
Handyman
Rewards Points: 512
Hard to say without knowing what the adhesive is but you can try either using a heat gun and a scraper or apply some paint remover and try scraping after it sits a while. Either way try either on a small section to start.
canadaclub is offline   Reply With Quote
The Following User Says Thank You to canadaclub For This Useful Post:
gohanman (01-06-2011)
Old 01-06-2011, 12:59 PM   #3
the Musigician
DangerMouse's Avatar
Light tan color squeaks of PL Construction Adhesive. In any case though, you are correct, scrape the heck out of it first.
Since you're refinishing, (a good thing too!) you might be able to scrape it down as far as possible, then sand off the remaining film to get to the wood.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
Old 01-06-2011, 01:21 PM   #4
Thanks. I guess scraping + sanding will be attack tactic number one.
Old 01-06-2011, 02:08 PM   #5
Rewards Points: 200
Dm is correct . try using a open cut paper first so as not to gum up the paper , then switch to the same grit regular paper , then skip one grit till you get to the final grit .[ 3 1/2 open, 3 1/2 closed , 60 , 80 100. ]. then 100 grit screen to remove any scratches from the paper . sand with the grain.
Floor Doc is offline   Reply With Quote
The Following User Says Thank You to Floor Doc For This Useful Post:
Removing glue from hardwood floors - sanding? jbitt Flooring 2 01-20-2010 06:10 PM
Removing Granite & Omni Grip Adhesive from Fireplace Surround RayJak Tiling, ceramics, marble 4 11-13-2009 04:28 PM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 09:38 PM
Recommedation for Removing Tongue on Hardwood Plank. anthony9887 Flooring 10 07-13-2008 06:44 PM
Removing carpet pad and paint from hardwood floors Rahci Flooring 10 05-14-2008 02:54 PM
