Identifying Existing Flooring Tiles? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-13-2011, 06:19 PM   #1
Identifying existing flooring tiles?
We pulled up the carpet in a bedroom, planning to redo the floor with some very cheap (33c/sqft) stick on vinyl tiles. They aren't fantastic quality, but we did another bedroom with them, and were very happy with the results.
Under the carpet, we found tiles! They seem to be some kind of adhesive tile.. not sure if they're lino or vinyl? Concerned about asbestos?
The carpet underlay was very stuck, and has left black marks/stains on the floor. Can we restore the floor? Can we just stick the new vinyl tiles on top? How would we prep it to do so? Can we remove the tiles (without dying of asbestos-inhalation)?
Help!
hdsheena is offline   Reply With Quote
Old 06-13-2011, 06:25 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 124
The only way to determine if they are asbestos is to have them tested. Any installed up thru the early 90's have a good chance of containing asbestos. The adhesive also probably contains asbestos and more than the tiles.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-13-2011, 06:27 PM   #3
So, if it does contain asbestos, just cleaning/restoring the floor (or, if possible, installing new tile on top) shouldn't be a health concern, right? Tearing it up, would be?
Old 06-13-2011, 06:32 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Correct.
XXX
Old 06-13-2011, 06:32 PM   #5
Rewards Points: 124
As long as you don't sand it. ..........You can take it up and scrape up the adhesive with little danger as long as you keep it wet during removal, if you need to remove it.
Old 06-13-2011, 06:38 PM   #6
All very good info. Given that..
The carpet underlay was very stuck, and has left black marks/stains on the floor. Can we restore the floor? Can we just stick the new vinyl tiles on top? How would we prep it to do so? Can we tell if it's vinyl or lino? Does it matter?
Old 06-13-2011, 09:59 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The old black adhesives were petroleum-based and I'm sure have stained the tile. I'm thinking you'll never get those stains out. Shouldn't matter if it is vinyl or linoleum. You should be able to apply the new tiles directly to what's there. No particular preparation should be necessary as long as the surface is flat and dry and clean.
XXX
Old 06-13-2011, 11:56 PM   #8
It's not adhesives (i think?) but just residue from the black foam underlay that was under the carpet. It's kind of like tiny bits of foam? Really tiny.. And stuck. To the tiles.
We're going to stick down a few tiles and leave them for a few days to be sure they seem to be sticking well, before doing the whole room, I think. In one area where the existing tile broke and came up, I think we'll just cover it with a new tile and hope it's okay..
loose tiles in bathroom exodus125 Tiling, ceramics, marble 1 05-10-2010 07:43 PM
Help identifying load bearing wall and flooring help! (video) mikedavid00 Building & Construction 6 04-03-2010 10:57 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 06:29 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
New Basement - Flooring Options Debate LAX2489 Flooring 6 02-22-2009 08:03 PM
