Old 01-05-2013, 10:25 PM   #1
Which is ideal for cement board and ceramic tile installation
I have just laid and leveled my new 3/4" plywood subfloor and moving to the tile installation. I was wondering if anyone knew which would be more efficient for the job of installing the 1/4" cement board and 12"x12" ceramic tiles.
See attached picture for mortar selections.
Shawn49424 is offline   Reply With Quote
Old 01-05-2013, 11:16 PM   #2
don't use anything in a bucket, only the bag stuff that you mix on site.
Old 01-05-2013, 11:22 PM   #3
Also make sure you lay a bed of thin set under the tile board, and tape all the seams with thin set.
Old 01-06-2013, 04:13 PM   #4
Tileguy
JazMan's Avatar
Unfortunately the adhesive manufacturers have been stretching the meaning of "thinset" and "mortar" for many years. I don't know who was the first abuser, but I guess once one did it the rest thought they also had to.
Thinset Mortar & Mortar by definition must be made from Portland Cement. Portland Cement can not be stored once mixed, it hardens in a matter of hours. Pre-mixed products do not contain Portland, and so can not be thinset mortar. But who's gonna tell them they have to tell the truth?
That product and those made by all the other manufacturers are really mastic with a little sand or ? mixed in the give it some texture. They are fine for vertical dry areas such as backsplashes, not a good product for wet areas and makes no sense to use them on floors.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 01-21-2013, 11:24 PM   #5
Still going...
ChrisDIY's Avatar
Jaz
Would that include an entire wall(s) in the DRY portion of a bathroom? Will be using mortar in shower and the floor.
Sent from my Samsung Galaxy Tab 2 using DIY Chatroom
--Chris the DIY Guy
Still going, on Ibuprofen...
ChrisDIY is offline   Reply With Quote
Old 01-21-2013, 11:42 PM   #6
Tileguy
JazMan's Avatar
The mastic would be ok to use on any wall away from moisture as long as you're not installing natural stone tiles. But, why would you want to?
It's not as good, plus for the cost of one 3.5 gal. pail you can buy two or 3 bags of quality thinset and get an equivalent of 10-13 gal. of mixed product.
Jaz
Old 01-21-2013, 11:54 PM   #7
Still going...
ChrisDIY's Avatar
Once I start it will take me two to three weeks to tile this bathroom, tile floor to ceiling. Just feel all the mixing will add to the time and labor. Thought mastic would be easier to stop and start...?
--Chris the DIY Guy
Old 01-22-2013, 10:16 AM   #8
It's not that hard to mix thinset, and it cleans up easier than it looks like it should.
zakany is offline   Reply With Quote
Old 01-22-2013, 10:31 AM   #9
Originally Posted by Shawn49424 View Post
I have just laid and leveled my new 3/4" plywood subfloor .
what steps did you use to lay and level your floor?
Old 01-22-2013, 10:56 AM   #10
Still going...
ChrisDIY's Avatar
I have already completed one bathroom, I guess I follow the mix, wait, mix again too closely, along with measuring out exact amounts of water...
Mixed 1/4 a bag at a time the last time and wound up wasting too much. Working alone.
--Chris the DIY Guy
Old 01-22-2013, 10:51 PM   #11
A bathroom scale and a liquid measuring device are your friends.
After a few times, you can do it by sight.
Especially the grout is important to mix in small batches. I would not hesitate to start with 3 lbs. if you have a digital scale or baking scale. With all the additives, the stuff is not getting any easier to work with. And I still feel the optimum temperature is about 55 degrees F.
You can always mix a bigger batch the next time.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
ChrisDIY (01-22-2013)
Old 01-23-2013, 09:00 AM   #12
You measure when mixing thinset?
I just put an inch of water in the bottom of a bucket and keep adding the thinset and mixing until it reaches the right consistency. Then I follow the mixing instructions on the bag (5 min mix, 5-10 min slake, remix).
Cleveman is right - a little grout goes a long way.
Old 01-23-2013, 12:57 PM   #13
The mastic would be ok to use...But, why would you want to?
Convenience. Convenience is a multi-billion dollar industry.
Having said that, I'm very surprised that such a reputable company such as Mapei would resort to such a decription on its product label. After the misleading title, they describe it as an "alternative to traditional thin-set mortars that require water and mixing."
As written, it's a little ambiguous as to whether they're trying to say it's an alternative to thin-set mortar, or it's a thin-set mortar that doesn't need to be mixed. I suppose they worded it this way on purpose, so that someone might interpret it as the latter. Nowhere in the technical spec sheet does it mention "mastic". So shame on them for that. They do mention all the limitations that you mentioned though.
jeffnc is offline   Reply With Quote
Old 01-23-2013, 04:30 PM   #14
I agree with Jazz. I have used both and would recommend thinset over mastic.
Awoodfloorguy is offline   Reply With Quote
Old 01-23-2013, 05:01 PM   #15
You probably wasted about $1 of thinset in that case. Don't worry about that.
Ceramic tile in a shower - Cement Board Floors Too? lemley98 Tiling, ceramics, marble 1 09-14-2012 08:09 PM
Ceramic Tile Floor Info Help RichardZ Tiling, ceramics, marble 36 07-26-2012 09:33 PM
Repairing ceramic tile shower jimmyj Building & Construction 1 04-25-2011 09:09 PM
Ceramic Tile over plywood, particle board hardwaremanager Flooring 5 04-12-2009 10:39 PM
Remove 3/4" oak floor before cement board and ceramic tile goes down?? 4just1don Flooring 8 10-31-2008 11:32 AM
