Old 06-03-2009, 12:45 AM   #1
I want top-quality solid 3/4" hardwood...
I'm shopping for the clearest, most consistently grained pre-finished 3/4" hardwood flooring I can find in either a white or red oak. Price is not a consideration...high, low, somewhere in between...I don't care.
Who makes the absolute best? This is going in a house with no kids or pets.
I've heard the hype from all the sales people...what do you people out there have to say?
Thanks a bunch.
janralix is offline   Reply With Quote
Old 06-03-2009, 11:55 AM   #2
Still Learning
Hmmmn...best? Canadian manufacturers are the ones to turn to. Mirage, Lauzon, and Mercier. But their hardwoods are more on the select and better appearance. Another source is Sheoga out of Ohio. Benefit here is longer overall lengths and I believe you can buy direct though I'm not certain.
Sheoga Clear White Oak
HardwoodGuy is offline   Reply With Quote
Old 06-04-2009, 07:02 AM   #3
Doer of Many Things
poppameth's Avatar
In Virginia the best place to go is a distributor called Long Floors. They carry a private labeled product called Impressions. It's very clean, comes white or red oak, and carries a 50 year finish warranty. It runs me about the same as lesser products from Armstrong such as Yorkshire.
poppameth is offline   Reply With Quote
Old 06-04-2009, 08:36 AM   #4
Price is not a consideration but you're going with prefinished oak?
jerryh3 is offline   Reply With Quote
Old 06-04-2009, 09:03 PM   #5
Wood Floor Guy
Yes, Mirage, Lauzon, Tembec, and several other Canadians make really nice clean floors. And Sheoga is also really nice. But for the cleanest grade, you really should consider going with unfinsihed and having it job site finished.
You ca pick a true Select, or even Clear grade, or if you want a spectacular floor, consider Rift and Quartered. You'd also have a square edge for an elegant look as compared to a bevel with the prefinshed.
I'm a huge prefinished fan, but you sound like a better candidate for unfinished.
Wood Floor Guy
Last edited by AtlanticWBConst.; 08-20-2009 at 03:52 PM. Reason: RULES VIOLATION: Advertising Link Removed From Signature
Wood Floor Guy is offline   Reply With Quote
Old 06-12-2009, 11:21 PM   #6
Good info...thanks. Pre-finished is only option due to time restraints.
Storing Solid Hardwood prior to install gwoman Flooring 2 01-20-2009 07:27 AM
Solid Hardwood direction daxinarian Flooring 6 09-18-2008 03:13 PM
Hardwood - engineered vs solid? cbeingessner Flooring 12 05-19-2008 11:37 AM
Quality of Pergo engineered HARDWOOD? Jeff12 Flooring 2 01-13-2008 10:17 PM
Does 5" Hardwood Solid need to be glued down as well as nailed down. reibuild Flooring 2 08-03-2007 11:37 PM
