I Think I Got Hosed By Inconsistent Tile Sizes - Flooring - DIY Chatroom Home Improvement Forum
Old 09-29-2011, 10:57 PM   #1
i think I got hosed by inconsistent tile sizes
Been using 3/16" spacers (those 4-corner type or whatever they're called). After putting nine 13x13 tiles and spacing them, I noticed other spaces had came apart by 1/16, and essentially threw the whole line off. It's also evident by the fact that some tiles, while butted up against spacers that are on a perfectly straight line, and even those corner spaces, stick out an extra 1/16" (and the only explanation I have for this is that the tile sizes aren't exact).
With a 3/16" line, can grout hide this issue? I'll get pictures up tomorrow if needed (gonna let them finish setting, just to see how bad it gets). Had a couple of good boxes with the same size, and then this box has whatever size they felt like putting in. >
Tonglebeak is offline   Reply With Quote
Old 09-30-2011, 06:29 AM   #2
DIY staff
Rewards Points: 7,174
That happens---that's why most floors are laid without spacers--just eyeballed into a grid drawn onto the floor.
Always check the batch numbers on the tile boxes----that helps but is no guarantee that the tiles will all be the same size.
Old 09-30-2011, 03:51 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 412
Maybe. How much were the tiles each or sq. ft.?
Even with high quality tiles spacers can cause problems. I've never used spacers when installing floor tiles.
Jaz
Old 09-30-2011, 06:18 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
It happens! I've been preaching for years that spacers aren't necessary and will only get people into trouble. Fired-clay tiles can always vary in size and what you pay for them doesn't mean a thing unless you cough-up an extra buck for "rectified tiles".
Layout a grid with chalk lines and lay the tiles according to the chalk line grid. If you have to fudge one now and then fudge it, but use your eyeball to do so. Stop expecting perfection because it isn't going to happen. The imperfection is part of the charm of real ceramic tiles. If you want perfection install a vinyl floor covering.
The grout will help but now that you are aware of the errors you will still see them immediately.
Old 09-30-2011, 08:21 PM   #5
Thanks. If perfection isn't expected with tiling, then I feel better. I'll just have to try to correct it with either the next row, or the rows that will go under the island. If the grout will help, thank god, but yes, I will always notice those errors lol. It's probably going to be one of those things where I'm the only one who will see the problem (I hope)
Old 09-30-2011, 08:27 PM   #6
MikeKy55's Avatar
Rewards Points: 254
Or be like me have to make an effort not to tell everyone who comes in
MikeKy55 is offline   Reply With Quote
Old 09-30-2011, 08:36 PM   #7
DIY staff
"Never apologize until someone complains."(Abigail VanBuran : Dear Abby)
Nominal Size of Tile, Lowes/HD vs Tile Store Thadius856 Flooring 17 09-12-2011 08:16 PM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 03:06 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 10:05 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
