I Need Bondo Help - Flooring - DIY Chatroom Home Improvement Forum
Old 03-16-2008, 12:02 AM   #1
help removing bondo from concrete
In the process of applying epoxy to shop floor and used bondo to fill cracks. Didn't put enough hardener in it so its not as hard as it should be. I removed a lot of it but theres still some stuck to concrete. Anybody have any suggestions on how to remove the rest?
shawnidaho is offline   Reply With Quote
Old 03-16-2008, 11:59 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,628
Ayuh,.... With a Grinder.....
Old 03-16-2008, 04:08 PM   #3
I removed the bondo in the cracks but there is still a residue about two inches wide on each side of the crack. I probably have 20 linear feet of cracks. How do I get the residue off of the flat concrete or should I not worry about it and epoxy over it.
repairing damaged wood on older doors, frames, etc (peeling, chipped, etc) joeyboy Carpentry 9 10-03-2007 08:33 PM
