Old 02-23-2012, 05:30 PM   #1
I have plywood floor on my shed.
Will it cause problems if I seal (finish only the top surface) by priming and painting.
ez2c is offline   Reply With Quote
Old 02-23-2012, 05:51 PM   #2
Disabled wood vet
titanoman's Avatar
What potential problems are you concerned with?
titanoman is offline   Reply With Quote
Old 02-23-2012, 05:56 PM   #3
The out house has a plywood floor and it gets painted every so often when we paint anything else around the property. The floor is in good shape, 20 years now.
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
Hardway is offline   Reply With Quote
Old 02-23-2012, 06:11 PM   #4
If the floor is already installed, painting the top side should not create a warping problem. I wouldn't paint one side of plywood that is in sheet form unless I am going to install it soon afterward or it could warp considerably.
MNsawyergp is offline   Reply With Quote
Old 02-27-2012, 04:31 PM   #5
My concern is moisture being absorbed on the unfinished side. It is nailed and may not be a concern, I know that I have heard of not finishing, only one side of wood.
All the input is greatly welcomed.
Old 02-27-2012, 04:41 PM   #6
That is the likely concern that I had. Now that it is nailed my thought is to paint the top surface.
Old 02-27-2012, 10:11 PM   #7
My dog houses have plywood floors and they never get painted on either side, they are 25 years old. roofs get replaced now and then, they are flat and not a lot of pitch.
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General Discussion 32 10-23-2012 09:54 PM
Underdeck shed , can i roof w/pt plywood & put deck boards to it? BigTy General Discussion 6 05-25-2011 02:45 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
shed plywood floor: treated? flamtap Building & Construction 6 04-24-2009 06:05 PM
shed floor plywood layout? flamtap Carpentry 4 04-24-2009 12:20 PM
