I Guess They Were Going For A "Tetris" Look With The Wood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Like Tree10Likes
  • 2 Post By r0ckstarr
  • 4 Post By spaceman spif
  • 2 Post By spaceman spif
Old 07-18-2016, 12:56 PM   #1
Rewards Points: 1,010
I guess they were going for a "Tetris" look with the wood flooring
I pulled up the cheap berber carpet so I could get to the original wood flooring in my li'l old house. The plan was to sand it down and refinish. I figured there would be some spots that were worn or had stains, but I wasn't expecting this.
(Click on the photo to enlarge it)
What the heck did they do? Or maybe I should ask why?? My guess is they replaced some bad pieces any way they could and figured to just cover it in carpet.
There are several problems here. One is this floor is from the 1960's, so I hope I can still buy boards the same size and style. Two is I need to replace more than it seems. If you look at the reddish vertical board that's in the middle of the pic (it ends at the foot long piece horizontal piece) you can see they shaved off about 3/8 of an inch all the way down the board. So all the vertical boards from that one to the left do not line up. (In other words, look at the vertical boards that are split by that one long horizontal board and you'll see they don't line up with each other).
Three, you can't tell by the pic, but the carpet actually runs underneath the wall and into the next room. They laid down the carpet and rebuilt the wall on top of it.
I can redo the wall, but I would love suggestions on how to deal with the wood floor.
spaceman spif is offline   Reply With Quote
Old 07-18-2016, 03:56 PM   #2
Rewards Points: 2,082
Re: I guess they were going for a "Tetris" look with the wood flooring
That looks like a bad patch job or maybe a remodeling gone awry.
Maybe this was one big room with a built-in counter or something, and someone decided that they wanted two smaller rooms, tore out the built-in, carpeted and built a divider wall on top.
You do know that in the mobile home business of long ago they would build the floor, carpet or vinyl cover the whole thing in the same carpet / vinyl, then build walls on top.
Maybe you can find enough flooring to cover the entire room, and either tear out all this, or overlay it.
ED
de-nagorg is online now   Reply With Quote
Old 07-18-2016, 06:27 PM   #3
r0ckstarr's Avatar
Rewards Points: 2,052
Maybe they buried a large container full of money under the floor. There's only one way to find out.
123pugsy and de-nagorg like this.
r0ckstarr is offline   Reply With Quote
Old 07-18-2016, 10:57 PM   #4
I dug and dug and dug! And underneath the floor I found.....my basement!
Old 07-19-2016, 01:07 AM   #5
r0ckstarr's Avatar
First basement with a skylight!
spaceman spif and de-nagorg like this.
Old 07-19-2016, 10:48 AM   #6
I'm gonna wait til my kids watch a scary movie down there then I'll suddenly poke my head in the hole and scream at them.
r0ckstarr and de-nagorg like this.
Wood flooring with round pegs identification Hestonian Flooring 10 05-08-2014 11:46 PM
Flooring Bondo or Wood Hardener Tom738 Flooring 1 09-03-2013 11:59 AM
Engineered or Solid Wood flooring on stairs VickyC Flooring 1 03-05-2010 06:50 PM
Old wood flooring - leaks from second floor p<0.05 Flooring 7 05-20-2009 04:41 AM
Bathroom wood flooring options? JamesEric Flooring 6 03-28-2009 09:03 AM
