Hump In Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-20-2011, 12:29 PM   #1
Hump in subfloor
Is it ok to use a wood floor edger to sand the hump out of a subfloor in order to avoid having to use floor leveling compound? The hump goes perpendicular to the floor joists in my kitchen and it is raised up about an 1/8", possibly a hair more. Just curious on how much is too much to sand out.
dcdrive747 is offline   Reply With Quote
Old 04-20-2011, 12:49 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
If it's SOLID hardwood flooring, I'd be comfortable doing it, but absolutely not if it's engineered/veneered/manufactured stuff.
If unsure what it is, lift out a register cover in that room and look at the edge of the flooring.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
dcdrive747 (04-20-2011)
Old 04-21-2011, 07:02 AM   #3
Getting There
MecGen's Avatar
In my kitchen I sanded the 3/4 thik subfloor at a joint (speedbump) at least 1/8 then covered it with a good linoleum floor. I prepped the floor first by screwing down the subfloor joint to stop movement and squeaks. I am watching this thred because the next floor in this kitchen, possibly winter 2011/12, I might go tile/ceramic, and I am unsure if I compromised the subfloor strength.
Maybe someone with more experience can give us the run down on floor prep, in the meantime I will do some searching around.
Thanx in advance
Frank
MecGen is offline   Reply With Quote
Old 04-21-2011, 07:39 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What is the material you want to sand? Is it in fact hardwood flooring, or something else?
What causes the hump?
What will you do next?
The more information you give the more accurate your responses will be.
XXX
Old 04-22-2011, 06:40 PM   #5
Getting There
MecGen's Avatar
Are you asking me??
My subfloor is just your everyday 3/4 tongue and groove plywood. It has a hi spot either because of the joist right below this joint is a little high or the two other joists (one on each side of the joint) being a little low. I did see on a "Homes" show that they just sand the floor more or less level.
your opinion?
Frank
Old 04-22-2011, 08:45 PM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
He is asking what the final floor covering will be. That would determine how to fix it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-22-2011, 08:53 PM   #7
the Musigician
Oh good grief. I need to learn to read. I didn't catch the 'subfloor' part....
Ignore my stupid answer please.
DM
Old 04-23-2011, 08:22 AM   #8
Getting There
MecGen's Avatar
Its my fault, I tried to hijack OP thred and kinda made it confusing
Frank
Old 04-23-2011, 08:31 AM   #9
the Musigician
Nah, it was 100% my not reading it correctly. I guess we all have 'those days'.
DM
Old 04-23-2011, 08:31 AM   #10
Rewards Points: 5,336
You can sand the subfloor to make the hump go away.
Ron
Old 04-23-2011, 08:38 AM   #11
the Musigician
Yup.
DM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
Replacing Subfloor whatispunk Flooring 1 09-01-2009 09:50 PM
Removing subfloor nickdu Flooring 3 07-28-2009 08:34 AM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 08:06 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
