How Would I Best Prepare This Garage Floor For Acid Staining? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-01-2007, 10:39 AM   #16
(I also should add that you'd have much more control over the swirls if you were working with a large, flat piece from above. I just poured in a little at a time into a plastic box from each mortar batch, slightly swirling with a screwdriver. And it's only the 2 black/white/grey ones, that other all grey piece, and the tan piece, were stucco color testers, no swirling on that haha)
joeyboy is offline   Reply With Quote
Old 06-02-2007, 07:14 AM   #17
DCsurfaces.com
DCsuperstore's Avatar
Send a message via AIM to DCsuperstore
I like the swirling effect. You should try it on your garage floor.
Our concrete countertop fabricators have tried a method like that with the countertop colors. They know what you mean about it being easy to over "swirl" and start mixing.
Good luck with the garage floor. I'd like to see photos when you've finished it.
DCsuperstore is offline   Reply With Quote
New Heated Garage: need help! HardcoreCBR General DIY Discussions 12 05-23-2008 08:34 AM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 11:38 PM
Staining a garage floor? Ledge General DIY Discussions 5 07-10-2007 04:57 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
