How To Work Out Threshold/transition Between Laminate/tile - Flooring - DIY Chatroom Home Improvement Forum
Old 05-04-2013, 08:16 PM   #1
how to work out threshold/transition between laminate/tile
So I am tiling my bathroom. Tire up existing tile and there is a slight difference in height between floor in bathroom and hall. Tearing up subfloor isn't an option since tub and toilet flange are already set. How should I have the substrate at the door threshold and where should my transition be?
I am attaching a picture. Plan to set hardiebacker and tile,with porcelain.
how to work out threshold/transition between laminate/tile-20130504_195352.jpg
fpr4 is offline   Reply With Quote
Old 05-04-2013, 08:33 PM   #2
DIY staff
Rewards Points: 7,174
Typically the transition is under the door when closed---this way you do not see a line of different color when the door is closed.
You have no real choice as the hall floor is existing---so I suggest you consider a wood transition piece ---flush to the tile if possible---what had you planned to use?
Old 05-06-2013, 12:38 PM   #3
The best I could think was to use this:
http://www.homedepot.com/p/MD-Buildi...0#.UYfc2KKsiSo
Old 05-07-2013, 06:09 AM   #4
DIY staff
If you have a table saw---you could make one that is ideal for the situation---the selection of wood transitions at the stores is very limited---
grounding the workpiece you're welding jarnold Electrical 43 01-03-2016 08:14 PM
Ceiling fan light doesnt work verpear Electrical 6 04-09-2013 08:44 AM
work schedule redman88 Off Topic 16 03-28-2013 08:50 PM
Pulling permits -- getting caught on previous UN-permitted work and effect on taxes jpfulton248 General DIY Discussions 11 01-22-2013 04:58 PM
Contractor didn't start work in CT - What recourse do I have? ControlTech Off Topic 3 09-28-2010 02:45 AM
