-   -   how to work out threshold/transition between laminate/tile (http://www.diychatroom.com/f5/how-work-out-threshold-transition-between-laminate-tile-178763/)
fpr4 05-04-2013 08:16 PM
1 Attachment(s)
So I am tiling my bathroom. Tire up existing tile and there is a slight difference in height between floor in bathroom and hall. Tearing up subfloor isn't an option since tub and toilet flange are already set. How should I have the substrate at the door threshold and where should my transition be?
I am attaching a picture. Plan to set hardiebacker and tile,with porcelain.
oh'mike 05-04-2013 08:33 PM
Typically the transition is under the door when closed---this way you do not see a line of different color when the door is closed.
You have no real choice as the hall floor is existing---so I suggest you consider a wood transition piece ---flush to the tile if possible---what had you planned to use?
fpr4 05-06-2013 12:38 PM
The best I could think was to use this:
http://www.homedepot.com/p/MD-Buildi...0#.UYfc2KKsiSo
http://www.homedepot.com/catalog/pro...081c75_300.jpg
oh'mike 05-07-2013 06:09 AM
If you have a table saw---you could make one that is ideal for the situation---the selection of wood transitions at the stores is very limited---
