How Is Vinyl Resilient Plank Flooring? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-03-2010, 10:10 PM   #1
how is vinyl resilient plank flooring?
i just put in engineered hardwood in my dining room and now i'm looking to replace carpet in my family room and need options other than carpet. i'd like to put in hardwood or engineered but the family room is the room that my kids and dogs spend the most time in. i don't want to put that in because i know it will get damaged, dogs scratching it, and various juices, paints, etc.
i need an option that will hold up to that wear and tear. from what i read laminate won't work, but i found vinyl resilient planks. from what i read they're pretty durable and can withstand water, won't scratch. i've found some planks that look like wood and is in 4" x 36" and 6" x 36" planks.
has anyone had any experience with this? or does anyone have any other options? i'll be doing this myself so i don't want to do anything too complicated.
thanks
tdeepness is offline   Reply With Quote
Old 05-04-2010, 07:57 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
Try the search feature. You will find hundreds of posts, pro and con. Mostly con.
For instance. Thoughts and opinions on "Trafficmaster Allure" flooring from Home Depot?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Installing vinyl plank over existing, uneven floor? AKCDIY Flooring 5 11-01-2014 05:48 PM
Feedback on Dura Plank vinyl flooring bmeredith40 Flooring 7 10-22-2013 01:03 PM
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 02:04 PM
Konecto vinyl plank floor john deere b Flooring 3 06-13-2009 01:27 PM
vinyl plank flooring? annie68164 Flooring 1 08-18-2008 01:10 AM
