How To Trim Out Laminate At Railing - Flooring - DIY Chatroom Home Improvement Forum
Old 06-30-2013, 10:16 PM   #1
jkk
Rewards Points: 233
How to trim out laminate at railing
This railing has a curved base. The laminate will meet this base at a curved surface. How can I cover this joint?
jkk is offline   Reply With Quote
Old 07-01-2013, 08:44 AM   #2
Rewards Points: 13,274
What your going to be dealing with around that whole set of stairs is just one of the many reasons I'd never suggest using laminate on a second floor.
How do you plan on transitioning around that top step without leaving a trip hazard?
Looks like your stuck with having to use a transition strip between the two.
Old 07-01-2013, 08:55 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
Try cutting the flooring on a back angle so just the top edge touches.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 07-01-2013, 12:45 PM   #4
jkk
Rewards Points: 233
Although the problem still exists, these are basement steps, from the first floor. I have a transition that I'm experimenting with. It is a very low ridge (1/8") but yes, might be a possible trip hazard.
Old 07-01-2013, 01:34 PM   #5
The problem I've had with a strip like that is if you look at the end of it all there is a paper thin layer of what looks like shelve paper. Step on it a few times and it's trashed.
It also tends to crack where it over lays the flooring because it's so thin.
Cutting that flooring at an angle is not going to work in my option. Reason being you have to leave room for expansion so there's going to be a visible gap and the core of the floor will be showing.
Old 07-01-2013, 03:11 PM   #6
Rewards Points: 3,416
About all you can do is cut the 1/8th ridge off,then under cut the transition piece so it will butt up flush to the flooring.
Canarywood1 is offline   Reply With Quote
Old 07-04-2013, 03:50 PM   #7
jkk
Rewards Points: 233
I think I'll buy a piece of hardwood bullnose, use a router to trim the bottom to get the right height, and maybe add a lip that slips under the laminate so that the laminate does not depress much when stepped on at the joint to the bullnose. Then get a stain that matches close enough.
Old 07-04-2013, 04:16 PM   #8
As long as you have a router just make a bullnose and cut a tongue to fit your engineered,instead of putting a lip to go under the tread.
Re-using laminate wingman1153 Building & Construction 10 04-30-2013 12:51 PM
replace trim on a laminate wall unit vzince Carpentry 4 03-03-2013 09:21 PM
Painting trim brown to match wood trim? Sofia26 Painting 2 12-10-2012 11:23 PM
New Roof but Fascia Trim Board Rotting ein0801 Roofing/Siding 6 07-15-2012 01:21 AM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 08:38 PM
