How To Tile Over Pine Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-09-2012, 09:29 PM   #1
How to tile over pine floor?
Ok the question, how to install tile on a pine floor.The floor is solid and i cant remove it because its under the kitchen cabinets. The wood is also about 1/2 inch higher then the next room, so what can i do with out raising the floor to much? Is their some kind of way to do this with out raising the floor much.
Thank you
Jack
jcarrdeer is offline   Reply With Quote
Old 02-09-2012, 10:01 PM   #2
Rewards Points: 13,270
Pine tells us next to nothing.
Is it plywood, 1 X 6 boards, ect?
Before even thinking about tile floors there's a few things that you need to figure out.
How wide are the floor joist.
How are they spaced.
What's the spans.
What type of subflooring do you have?
Old 02-10-2012, 06:30 AM   #3
DIY staff
Rewards Points: 7,174
Pictures will help here---
There are ways of cutting out flooring that goes under cabinets---
In a nut shell---NO--dimensional lumber moves to much with the seasons and should be removed or isolated with plywood and backer board---Mike----
Trafficmaster Ceramica on pine finished floor KURTZU2 Flooring 4 03-06-2012 11:06 AM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
Porcelain tile over linoleum floor Jac121 Flooring 11 01-06-2012 08:32 AM
Installing floor tile but don't want grout gap to turn black overtime gatorade Flooring 4 02-07-2011 12:13 AM
Removing floor tile glue from a wood floor mrmordun Flooring 2 09-03-2008 10:41 PM
