How To Support Flooring On A Slab Construction - Flooring - DIY Chatroom Home Improvement Forum
Old 08-31-2010, 12:08 PM   #1
how to support flooring on a slab construction
Problem: Hardwood flooring (t&G) laid on stringers that rest on cement slab. But some staggered ends do not line up with stringers, so the ends flex down and are not supported in these spots.
I was thinking of drilling 3/8 inch hole near ends, and filling void with some material to support the ends. Perhaps expanding foam; then putting a wood plug in the hole.
There are too many spots to try to remove the boards, which would require resanding the entire floor.
any suggestions??
parker300 is offline   Reply With Quote
Old 08-31-2010, 01:22 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
Start over.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-31-2010, 06:32 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Start over.
AMEN!
That's not the way to do that floor installation.
XXX
Old 08-31-2010, 06:49 PM   #4
Registered User
Rewards Points: 526
Figure #2, and 3: http://www.buildingscience.com/docum...ms?full_view=1
Gary
Old 08-31-2010, 07:15 PM   #5
Rewards Points: 148
Wood stringers on a slab is a time bomb. It will fail sometime.
Tags
un-supported ends
Plank flooring for new construction DidjaDewit Flooring 3 10-17-2012 04:56 PM
cork floor on slab alihawk Flooring 4 06-27-2010 05:42 PM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 05:48 AM
Prepping a slab for kitchen island tiger275 Plumbing 10 05-02-2009 04:03 PM
Plumbing Under Slab (New Construction) zzyzx Building & Construction 9 11-22-2008 12:41 PM
