How To Support Floor For Saltwater Fish Tank - Flooring - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 07:34 PM   #1
how to support floor for saltwater fish tank
Hello
Im upgrading my hobby to a 150 gallon saltwater tank the problem is the place where i want it the floor joist goes paraleal with the tank on the second floor I have 2x10x14 wood joist 16"on center underneath the floor is my garage but its in the middle of my garage door there is only 8" between the frame work and the floor,my question is the tank is 6' feet by 2' its going between a non load bearing wall I would like to build a stand for it to span out the weight load between the joist the load would have to be behind the wall any ideas on how big the stand would have to be.I was also thinking about adding a couple of TJI beams or doubling up a couple of joist any help would be great thanks
gilpin guy is offline   Reply With Quote
Old 12-08-2010, 09:24 PM   #2
Rewards Points: 1,574
Are you talking a 150 lb tank empty or full, or a 150 gallon tank? If 150 lbs full, I don't think you need to do anything (think weight of an average person standing there wouldn't require floor reinforcement). If 150 gallon tank: water is about 8 lbs/gallon, I think, so 150*8=1200 lbs. Now you have to be concerned but I've no clue how to address the issue.
bob22 is offline   Reply With Quote
Old 12-08-2010, 10:01 PM   #3
Its a 150 gallon sorry for the mistake roughly 2,000 lbs
Building a large Fish Tank - How? darenrogers General DIY Discussions 3 01-20-2010 07:50 PM
Load Bearing Wall- In wall Fish Tank cmh1027 Building & Construction 13 01-08-2010 06:20 PM
Fish tank plumbing problems.. Raibaru Plumbing 2 12-15-2009 03:13 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
GFCI for a fish tank? fw2007 Electrical 6 10-05-2007 01:06 PM
