How Should Laminate Flooring Be Secured Next To Brick? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-05-2010, 04:51 PM   #1
How should laminate flooring be secured next to brick?
Hello All,
I want to install laminate flooring in a family room that has a brick fireplace. Part of the laminate would be directly next to the brick base of the fireplace. What kind of base-board or base-piece would I use to secure the edge of the laminate against the fireplace?
-M
thecgmguy is offline   Reply With Quote
Old 09-07-2010, 12:16 AM   #2
Hrm, you might be able to use strips of quarter round. Although, I am a newbie idiot - so consider it an idea.
Hammerhands is offline   Reply With Quote
Tags
brick , fireplace , flooring , laminate
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
How do you install laminate flooring under door casings? Player Flooring 34 07-16-2010 04:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
Laminate Flooring around a brick fire place pamedic13 Flooring 6 11-21-2006 08:42 PM
