How Should I Fill This Sunken Room? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-17-2010, 11:45 AM   #1
How should I fill this sunken room?
I have a sunken living room that is 19' x 14' and 4" deep. It has a 4'' concrete wall all the way around the edges. Can I just fill it with concrete or will the weight strain the house too much?
A family member suggested using 1 or 2" concrete foam blocks and the rest concrete. Is this a better idea or should I just stick with all concrete?
The only reason I do not make a floor with 2x4 and plywood is because I live around New Orleans and prone to flooding. I plan on laying ceramic tile down and I do not want the chance of flood water filling in the sunken room and having to rip out all the flooring. And the deep echo sound is another turn off for a plywood subfloor.
Any other ideas are welcomed.
kingcire is offline   Reply With Quote
Old 09-04-2013, 12:59 PM   #2
I am in New orleans too. And want to fill in my sunken room. Have you filled in the room? Who did you use? And are you pleased? Thanks
hibob is offline   Reply With Quote
Old 09-04-2013, 04:20 PM   #3
Rewards Points: 13,472
Both of you need to post some pictures.
Hi bob you need to go back and add your own post.
Old 09-04-2013, 09:53 PM   #4
Rewards Points: 944
I'm not in New Orleans and I don't have a sunken living room, but I wish I did.
cleveman is offline   Reply With Quote
Old 09-05-2013, 05:04 AM   #5
DIY staff
Rewards Points: 7,174
I believe you will be fine----the extra weight should not be a problem on a slab.
A few more details will help.
Old 09-05-2013, 11:19 AM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 92
I would just fill it with dirt and plant flowers.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-05-2013, 12:17 PM   #7
I thought about turning mine into a pond for the cats to catch fish that way I don't need to be home to feed them at a certain time.
Actually, my sunken room is currently raised and covered so I can't see anything but I drilled though the plywood and discovered it is only 6" deep by 12' x 15' a least thats the measurement of the hallow sound I hear when I stomp my feet.
I have heard I don't need lightweight concrete to I do need lightweight concrete and Styrofoam to lighten the weight. I want this done right and I am not sure the correct method in a warm climate.
I plan on tiling over the new concrete.
Old 09-05-2013, 05:46 PM   #8
Framing Contractor
Rewards Points: 118
Why not just frame over the area and install plywood. Sounds like it is already framed over though. Is the current floor framing inadequate to support tile?
sixeightten is offline   Reply With Quote
Tags
concrete , fill , living , room , sunken
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 02:49 PM
What Makes A Room A Bedroom? HowToGuy Remodeling 11 02-26-2010 02:44 PM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 07:28 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
A room in a room? artosie General DIY Discussions 2 03-10-2009 12:43 PM
