Riser should be in place first, does that nosing have a dado so it will cover up the gap at the top of the riser?
I would not count on air gun nails, need constrution adhesive and real long galvinized finish nails set in predrill pilot holes.
I use galvinized because there rough and hold better.
You can also get a plug cutter, drill a countersink the same size for two or three screws, and then fill the countersink with plugs cut from the same wood.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
