Old 03-07-2009, 12:00 AM   #16
JJ1
Sorry for the hyjack. As you can see I have been labeled a 'newbie' & need to brush up on my manners. My local tile 'experts' are telling me to get busy laying the tile directly on the concrete. The home is 10+ years old & what few cracks are there are very minor... 1/8'' in width or less. None of which have any signs of verticle heave. I was concerned & inquired with several about using a membrane product to cover the length of cracks. They all said the same...'don't waste your time'. I want to do it right....home owner on the other hand is more of a risk taker. He is not concerned with the potential for movent that could damage the tile. The slab was poured over a plastic vapor barrier. I assume this minimizes the risk for moisture moving upward. I am also planning to use modified thin set with the porcelin tiles. It is my understanding that this combination is what you would even use in outdoor applications.
I did look at the Dirta product on-line & see clearly how it will take away all the worries. This would double the expense to the home owner I'm sure. I'd call it a solid insuranse policy. Thanks again for the input, J.J.
By the way, what are your cradentials? I am also looking forward to here BUD CLINE'S (Tile Guy) opinion.
JJ1 is offline   Reply With Quote
Old 03-07-2009, 12:31 AM   #17
JJ1
If it were my chose I would go with the concrete makeover. I have seen many commercial buildings with polished, stained & sealed concrete..... absolutely amazing. It's safe to assume that the wearabilty & low maintenance get high marks. In this case the home owner is gonna have their tile. Thanks, J.J.
Old 03-15-2009, 11:00 PM   #18
Does anyone have any suggestions how I would find someone in my area to grind my uneven concrete or micro plane it for stain preparation?
2249diy is offline   Reply With Quote
Old 03-16-2009, 07:58 AM   #19
Check the listing at http://www.concretenetwork.com/?p=Websites
Bob Mariani is online now   Reply With Quote
Old 03-16-2009, 06:20 PM   #20
part of the allure of acid-stain'd conc IS the antique look post-stain & seal'd w/a good sealer,,, IF you need to ' sand ' the floor, do it all w/clark oscillating machine,,, tsp & blk pad on a lo-rpm buffer to clean up prior to acid.
you might be able to find a guy who's grinding & polishing but i'd bet the min charge's $1,500,,, even tho its my work, i won't have my conc done at that price,,, just acid & sealer
yesitsconcrete is offline   Reply With Quote
More On This Topic
Okay now we’re going to talk a little bit about floorings. One flooring a lot us have in our homes that we don’t even know we have and we can utilize is a concrete slab. A concrete slab, you can strip your wall to wall carpeting and take the... Read More »
When undertaking a home improvement project, you need to know how much concrete you will need and what kind is best for your project. Determining the right amount and kind of concrete you need will save you money and trouble in the long run. Read on to... Read More »
How to Trim Tile
How to Trim Tile by eHow.com
Applying tile to a room can add interest as well as accentuate architectural details. Choosing the right tile for trim is very important and can add the proper finishing touch that makes or breaks a project. Read this article to learn more. Read More »
Creating an inviting outdoor space by building a patio is a great idea, but can become a great headache if not well thought out. Put together a budget and develop your project plans before getting started and your wallet and home will thank you for it. Read More »
Alright, now we’re going to cover the tile options that there are for your countertops, your bathrooms, on the counters, in your showers, anywhere you wanna put tile. There’s a number of different options. The mosaics, which are beautiful... Read More »
Cutting out a concrete basement floor jeffhoward001 Building & Construction 17 05-02-2009 10:50 AM
installing shower pan on a concrete floor sv9779 Remodeling 16 12-31-2008 09:23 PM
Floor Issue... (Concrete) akthomp Flooring 14 09-05-2008 09:57 AM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 06:04 PM
cold concrete floor RuthP Flooring 4 02-04-2008 12:13 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
