How To Safely Remove Hard Water Stains From Santo Tomas Marble - Flooring - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 11:26 PM   #1
How to safely remove hard water stains from Santo Tomas marble
Hi,
My shower has Santo Tomas walls and it has hard water stains.
Tried diluted CLR but it made it opaque.
What should I use to safely remove hard water stains from santo Tomas marble?
Already installed water softener, but still need to remove the stains
Thanks for your help.
Jorgeelizondom is offline   Reply With Quote
Old 07-27-2012, 08:42 AM   #2
DIY staff
Rewards Points: 7,174
Any product that contains acid will remove the gloss on the marble---I suggest you call a marble polishing company---
If the tiles are mat finished---a random orbit sander with very fine grit could be used---
Old 07-27-2012, 09:20 PM   #3
You are going to have to hone the marble.
Jeffrey James is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
Hard Water or Water Heater Sediment ? sdcards Plumbing 6 08-20-2006 06:37 PM
