How-to Replace Subfloor Next To Exterior Walls - Flooring - DIY Chatroom Home Improvement Forum
Old 07-27-2006, 06:10 PM   #1
how-to replace subfloor next to exterior walls
i'm in the middle of replacing an entire subfloor on a second story, and have a few questions:
- what do i do where the existing subfloor meets an exterior wall?
- some of the panels i've already put down only have 3/8" - 1/2" of the edge bearing on a joist. i know it should be 3/4", but i was working late at night, my measurements were off, etc...do i need to rip up and replace? seems sturdy now, but i don't want the floor to fall in.
thanks everyone
tdonly is offline   Reply With Quote
Old 07-27-2006, 08:49 PM   #2
Could you post a picture so that I can get a better understanding of what you are asking?
It sounds like you may want to nail (sister) on a piece of lumber for a nailer to the current joist .
redline is offline   Reply With Quote
Old 07-28-2006, 12:41 AM   #3
renovations
What are you going to be putting down as a finish floor? Unless it's tile you've probably covered yourself well enough. ( And maybe even then) A lot of new construction floors are looking good with a whole 1/2" of bearing.
My concern would be where the new subfloor is not supported near the wall. I'd screw some backing under there to support the edge.
What was the existing sub?
Bonus is offline   Reply With Quote
Replace a skylight dome only?? Phil Ervin General DIY Discussions 14 10-23-2016 08:06 PM
How hard is it to replace linoleum? Alan Flooring 5 03-01-2007 09:52 PM
how to replace GFI Bob L. Electrical 1 10-05-2006 08:50 AM
