-   -   How to repair an uneven concrete subfloor? (http://www.diychatroom.com/f5/how-repair-uneven-concrete-subfloor-28318/)
poofy 03-29-2005 02:13 PM
I'm going to be installing some mannington or bellawood hardwood floors in the next month. I currently have carpet and the subfloor is concrete (above grade). I plan to use the glue down method.
The problem is that the concrete subfloor is extremely uneven to a degree as much as two inches. From what I've read, this can be fixed by using a large amount of quickcrete or other type of concrete. I have no problems buying 30 seventy pound bags and leveling the floor out.
What I would like to know is what are the typical pitfalls I may run into? If I get some of the concrete mixture on the walls, is that an issue? I have floor to ceiling windows - the bottom 5 inches is metal - can I apply the concrete against the metal? What are the other issues?
I plan to live in this place for a long time and I don't mind some very hard work. I just want to get it done right.
MgMopar 07-12-2005 08:32 AM
Here is a link to another thread about leaving a floor
http://discussdiy.com/showthread.php?s=&threadid=194
