How To Repair Snap And Click Flooring That Keeps Coming Loose? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-23-2010, 11:39 AM   #1
How to repair snap and click flooring that keeps coming loose?
How to repair snap and click laminate flooring that keeps coming loose?
Missy09 is offline   Reply With Quote
Old 06-23-2010, 12:09 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
other than glue i don't know,you may need to get new pieces as the lock gets damaged the more times you lock and unlock it
Tom Struble is offline   Reply With Quote
Old 06-23-2010, 12:56 PM   #3
Handyman
Rewards Points: 512
whenever I install laminate I always put a small dab of wood glue, like Lepage or something) on the ends. Not a lot but just a dab. Never had a seam break yet. But, if it has already split you have two options...
1) put some running shoes on and kick one plank toward the other, or
2) remove a piece of baseboard or quarter round (enough to see the gap at the end) and use this tool to hammer it into place. $12 at HD Place the right side between the wall and the plank course, then hit the left side with a hammer..tadaaaa.
canadaclub is offline   Reply With Quote
