How To Repair The Jigsaw Subfloor To Prepare For Tile/stone Installation - Flooring - DIY Chatroom Home Improvement Forum
Old 05-03-2010, 11:47 PM   #1
Rewards Points: 87
How to repair the jigsaw subfloor to prepare for tile/stone installation
The bathroom sub floor was cut to lay/move some pipes, then I put the pieces back together and nail them back to the joist. Do I need to fill the cracks ? Do I need another layer of plywood if I want to install tile/stone later? What should the layers be?
A picture is worth a thousand words.
Stephen S. is offline   Reply With Quote
Old 05-04-2010, 06:59 AM   #2
DIY staff
Rewards Points: 7,174
If the original subfloor is 3/4 inch--add another 1/2 inch on top. then Durrock.
If the original 'Jigsaw'' is not structurally sound--you should replace that first.--Mike--
Old 05-04-2010, 09:26 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 232
Make sure that any small patch is supported by 3 joists minimum. A small piece of plywood subfloor is not structurally sufficient if it rests only on 2 joists. Of course adding the second layer of "underlayment" grade plywood may fix that in this case. Regardless of the subfloor you need 2 layers of plywood for natural stone tiles. In addition the the subfloor you'll probably need to stiffen the joists too.
After you take care of the subfloor requirements you can choose a CBU, such as Durock or Hardie, or a membrane such as Ditra or one of Noble's fine products.
Jaz
Old 06-08-2010, 03:53 PM   #4
Rewards Points: 87
The first layer of plywood (3/4") is perpendicular to the joists but does it matter whether the 2nd layer of plywood (1/2") be perpendicular to the joists as well ?
Best way to repair poor drywall installation? RyanD Drywall & Plaster 5 05-19-2009 09:13 AM
Prepare ceiling in basement for future AC installation ordoro HVAC 1 11-25-2008 01:18 AM
