How To Remove Snapped Screw On Hardwood Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-14-2013, 09:49 PM   #1
How to remove snapped screw on hardwood floor?
I got a snapped trim screw on the jatoba hardwood floor. I put the screw there to fix an installation problem. But the holes on the hardwood plank is not big enough and the screw snapped. Is there any way to remove the screws?
Many thanks for your assisstance.
mechth is offline   Reply With Quote
Old 12-15-2013, 03:14 AM   #2
DIY staff
Rewards Points: 7,174
Removing nails, etc.. - Woodworking Talk - Woodworkers Forum
Look at post 13 by mikeswoods----the hollow drill will allow you to neatly remove the screw---you will need to cut a plug from some scrap stock to plug the resulting hole---
Old 12-15-2013, 06:26 AM   #3
Rewards Points: 13,712
Should have been using a finish nail driven in at an angle.
mechth (12-15-2013)
Old 12-15-2013, 08:41 AM   #4
the subfloor below is not flat and finish nail is not going to hold down the floor plank. that's why I decided to use a screw.
Old 12-15-2013, 08:42 AM   #5
very interesting. I will give it a try.
Many thanks.
Old 12-15-2013, 02:17 PM   #6
DIY staff
You are welcome!! We use to make those from old pushrods from a car engine--nice to see that you can buy them already made.
Old 12-15-2013, 04:49 PM   #7
Rewards Points: 1,242
That page seems to be missing in my book.
Getting it out is one thing but determining what caused the problem and how to avoid it in the future will be the real time and frustration saver.
Old 12-28-2013, 06:54 PM   #8
Rewards Points: 3,626
He more than likely didn't predrill the hole for the screw,and that's what caused the head to shear off.
When he gets it out he will need a plug cutter to finish the job.
Canarywood1 is online now   Reply With Quote
Can I glue down an Armstrong locking hardwood floor? Fixitgeorge Flooring 10 01-30-2013 11:49 AM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 01:08 PM
Sheared head on Tapcon screw - how to remove? mkuether Remodeling 9 12-04-2008 08:18 PM
Hardwood Sub Floor Concern Karmen Santourian Flooring 6 04-23-2008 09:07 AM
