How To Remove Particle Board Mortared To Plywood? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-01-2011, 11:58 PM   #1
How to remove particle board mortared to plywood?
We have removed old tile in preparation for new ceramic tile in our front entry way. Once the tile was broken up and removed, we discovered particle board underneath. We tried to bring this up, but it has been set on the plywood underneath with mortar! Any tips or tricks for how we can get this up? New plywood has been laid everywhere else to reinforce the subfloor, and the plan is to put down Ditra, however there is not enough room to put plywood or Ditra down on top of the particle board at the front door where the tile was as the height would then be level with or above the door jamb.
k8park is offline   Reply With Quote
Old 01-02-2011, 06:47 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 788
From my experience, just jump in there and chip it out in chunks. There really isn't any magical ways to get it out, that I am aware of. You got your work cut out for you for sure.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Installing backerboard - replace particle board? salvop Flooring 10 04-29-2011 10:32 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
Particle board underlayment help diynut Flooring 5 03-07-2006 05:22 AM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 08:32 PM
