How To Remove Paint From Concrete Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-02-2011, 11:37 AM   #1
How to remove paint from concrete floor?
I am tiling basement floor and was told not to tile over painted concrete. The paint is that grey floor paint seen on many basement floors(not sure what type) so how do I remove paint or is it better to use some sort of underlay? Please help!
Jadams13 is offline   Reply With Quote
Old 09-02-2011, 12:05 PM   #2
the Musigician
DangerMouse's Avatar
Please do not post duplicate threads asking the same question. It makes it hard for our members to help you. This one thread is sufficient. Please be patient.
DM
Old 09-02-2011, 12:33 PM   #3
Did you try with resolvent?
BrendaSimons is offline   Reply With Quote
Old 09-02-2011, 01:01 PM   #4
DM
I did not post duplicate posts on purpose. The first time I tried to send it there was an error, so I figured it did not work. So I tried it again, after I sent the second one with no issues I realized the first one was there.
Old 09-02-2011, 02:59 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
NEVER use any type of chemical solvent to remove paint from concrete that you intend to apply ceramic tile over.
The paint as well as the solvent are both bond-breakers when it comes to ceramic tile adhesives.
The paint should be mechanically removed.
XXX
Old 12-23-2012, 02:00 PM   #6
Rewards Points: 340
I just removed some 6x6 tiles from a back porch that had been painted and then tiled
we estimate the tile had been installed 15 years ago on a painted surface
it took considerable elbow grease to break the bond between the thinset and the paint
I believe you can install tile over painted concrete.Oh yeah the concrete was a 2''
topping over a floor made of railroad ties that had been placed side by side to span 7'
is it against the rules to open up an old post ?
kt82 is offline   Reply With Quote
Old 12-23-2012, 02:19 PM   #7
the Musigician
Never! (unless you're a spammer....) However, it's in your best interest (if you wish a speedy reply) to start your own thread in the appropriate sub-forum.
DM
The Following 2 Users Say Thank You to DangerMouse For This Useful Post:
DiyCR fan (03-16-2013), kt82 (12-23-2012)
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
garage floor nana k Flooring 3 08-28-2010 01:24 AM
Epoxy Paint on Previously Painted Concrete Floor goodkarma Painting 6 07-10-2008 01:04 PM
