How To Remove Luan - Flooring - DIY Chatroom Home Improvement Forum
Old 02-26-2011, 08:58 AM   #1
How To Remove Luan
I am taking up the linoleum in the bathroom so I can install tile. The laun seems to be glued down and I am trying to figure out what is the best way to get under the laun to remove the linoleum and luan. I would have thought that I could get under the edge at the door transition at the hallway, but this stuff (luan) is really sealed tight with an adhesive. The bathroom is only about 32 sq ft. of floor. There is an air register in the floor as well and the same issue with the adhesive holding the luan down. Wherever I try to pry up to get started, it just wants to rip and shread the luan. Any suggestions?
David
djmdoitmyself is offline   Reply With Quote
Old 02-26-2011, 09:29 AM   #2
Coatings Nerd
Yep, thats what it does. Get a small flat pry bar, and a hammer, and some safety glasses....Then proceed to take out all your frustrations on that floor. Mine was glued and stapled down. Have to go back and pull all the staples, or hammer them in.
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 02-26-2011, 11:39 AM   #3
So I should take the flat pry bar and force it between the luan and the plywood and basically split it away from the plywood? I will try that and hopefully they did not totally cover the surface with adhesive.
Thanks.
David
Old 02-26-2011, 11:44 AM   #4
Rewards Points: 1,514
If you just attack the luan and there was a lot of adhesive, then you will very likely mar the subfloor so badly you will need to use resurfacing compound (before you can put even a new sheet of luan down).
One thing worth trying, ironing the floor to see if heat softens the adhesive.
AllanJ is online now   Reply With Quote
Old 02-26-2011, 11:51 AM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 130
It will be a pain. Luan is never to be glued down, so it was probably an amateur. So you may find other surprises.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 03-13-2016, 09:18 AM   #6
Rewards Points: 2
Re: How To Remove Luan
I see this posting is pretty old but for those who maybe looking for an answer, it sometimes is just easier to take up the subflooring and replace it. I have saved a lot of time that way.
mrat111 is offline   Reply With Quote
The Following User Says Thank You to mrat111 For This Useful Post:
joecaption (03-13-2016)
How do you remove a wood stove and bricks from living room? SimpleJack Remodeling 13 08-28-2011 01:26 PM
best way to remove areca palm root system Dus Landscaping & Lawn Care 0 01-23-2010 09:40 AM
Frigidaire/can't remove front water/ice dispenser tigerfan44 Appliances 0 12-17-2009 10:45 PM
Remove old light fixture (hanging) dj928 Electrical 9 12-02-2009 11:42 AM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing/Siding 3 07-02-2008 02:10 AM
