How To Remove Glued Down Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 10:15 AM   #1
How to remove glued down carpet
Is there a chemical that will disolve carpet glued to a cement floor or is the only way to remove it, with a scraper and pliers?
Terriarmstrong is offline   Reply With Quote
Old 10-04-2010, 12:10 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Cut it into strips and pull it up with pliers. Chemical removers could affect whatever you intend to install next. Besides, you would still have to get most of the carpet off first. There is no chemical that you can just pour on the carpet. You can rent a machine that will scrape it up.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 10-04-2010, 05:10 PM   #3
the machine is SO much easier. i dread removing glue down from cement. when i find glue down on particle board the skilsaw is your tool of choice. just pull it all.
racebum is offline   Reply With Quote
Old 10-04-2010, 05:36 PM   #4
Senpro.com makes some stuff. I used it once on some stuck glue and it worked. Just read the directions. Kind of expensive so renting a machine might be the better way to go.
JCW355 is offline   Reply With Quote
Old 10-04-2010, 10:31 PM   #5
jlhaslip's Avatar
Rewards Points: 2,866
Most carpet glues are heat sensitive.
If the site conditions at the project allows, dump some Hot water on the carpet, wait 5 minutes and it will pull up loads easier.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr chetsy Off Topic 9 12-03-2008 06:41 AM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 12:28 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
Carpet Nightmare The Nomad Remodeling 3 09-30-2007 08:25 PM
Need to remove baseboards that are glued and nailed recklessrick Painting 7 10-14-2005 05:20 PM
