Old 02-15-2012, 10:20 PM   #1
How to remove ceramic tile
I recently started remodeling the bathroom of my 1966 house. There's a tiled shower stall and tile floor that I'm attempting to demo. The joint between the wall and floor has been leaking, plus its time to update the bathroom.
My problem is that I'm finding it impossible to get the tile off the walls! Under the 4x4 tiles is about an inch of concrete and under that is metal lath, and behind that is the studs. The tiles aren't popping off when I chisel them from sides, they are only breaking off in tiny little pieces. I've only been able to get this stuff off by beating it with a hammer and then chiseling the remaining pieces. Then I'm left with broken chunks of concrete and metal lath still attached to the wall.
How do I get this tile/concrete/lath off the wall?? I've just been using a masonry chisel and regular hammer so far and removed about 3sqft in 2 hours. Maybe I need to get a sledge and crowbar?
gbook2 is offline   Reply With Quote
Old 02-16-2012, 01:07 AM   #2
Super Moderator
A little bigger hammer-----punch a line---then grab and pull --or use a flat bar ti pry off bigger sections
after you punch a line or two---gloves--goggles and a mask---If you use a Saws All--insert the blade backwards to get a shallow cut---you don't want to hit piped or wiring---Mike---
oh'mike is online now   Reply With Quote
Old 02-16-2012, 07:06 AM   #3
Stay-at-home GC
Rent a Demo Hammer (4 hours should do the trick). Safety glasses are a must for demoing tile.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 02-16-2012, 07:53 AM   #4
This is what I use. http://www.cpotools.com/bosch-11224v...n={OrderItemID}
If the concrete goes all up the wall I use a diamond blade in a 4-1/2 right angle grinder to cut the inside corners.
Old 02-16-2012, 01:40 PM   #5
Thanks for the replies!
I got a demolition hammer today, so I'll see how that goes. My wife was actually working on the wall yesterday while I was working elsewhere in the house. She's 120lbs and very gentle with the hammer, usually holding it about halfway on the handle. In 2 hours, she was able to get through about 4sqft, so hopefully with a powerhammer and me helping her, we'll get it done quicker.
I'm also assuming the stuff under the tile is not concrete, but mortar? They really built those walls to last, except where the wall/floor joints failed because of house settling. This is a second floor bathroom in a 2 story colonial. What can I expect to find under the floor tile??
Old 02-16-2012, 03:48 PM   #6
Stay-at-home GC
Most likely a mud bed with a lead liner under it. I think. Now a days, you'ld most likely find rotten OSB
Old 02-16-2012, 03:56 PM   #7
Wow, a mud bed sounds like 2" of concrete. That should be fun So I can expect that under the shower floor? What about under the rest of the bathroom floor? It has those 1x1 tiles, but thankfully nothing on the non-shower walls.
Is the demo hammer the best way to get up the mud bed? I'm worried about damaging the underlying joists and studs by hammering too much. We seem to have already broken the light fixture on the other side of the shower wall from all the hammering. Maybe with the demo hammer we won't shake things so much.
Old 02-19-2012, 03:17 PM   #8
I just removed old tiles in the bathroom on the 1st floor. I used hammer and pry bar. I just hit titles hard with the hammer and pry them with pry-barPlease wear Eye and Respiratory protection.
It took me about 1 hour for 27 sq ft. I broke mud bed underneath, but I am planning to re-install new one over concrete slab.
No CBU this time!
almazon is offline   Reply With Quote
Old 02-19-2012, 03:24 PM   #9
Tileguy
JazMan's Avatar
No CBU this time!
What do you mean? You wouldn't be installing a CBU on a slab.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 02-19-2012, 03:39 PM   #10
Jaz
Thanks for your fast reply!
Absolutely not! I ve learned it hard way. I was going to do it in the beginning, but it looks like you glueing 2 pieces of metal with Crazy Glue!
Anyway, once I saw its not holding well, I was smart enough to take that CBU piece off and scrape all Thin-Set Mortar off before it dries out.
Thats why I said No CBU this time!
I need to raise my slab a little bit. About 1/2 inch before installing 12x12 3/8 Ceramic Tiles. Its not damaged, not perfectly leveled. Would you use Mortar Bed or SLC?
Thank you in advance,
almazon
Old 02-19-2012, 04:26 PM   #11
Tileguy
JazMan's Avatar
Although it's possible to properly bond a thin mud deck to a slab, I think you'll have better luck with SLC.
It can be tricky, but you shouldn't have any trouble if you follow directions & ask questions here.
Jaz
Old 02-19-2012, 04:42 PM   #12
Well, I still deciding. The thingy is that my bathroom is T shaped. When you enter, toilet on the Left and sink on the Right.
I am afraid if I will pour SLC left and right I wont have enough control. I like it better cause it is easier, but I think I might wanna try Mortar Bed.
Mix it with little water, pour it, level it, Spray some water and slurry it. Right?
Thanks again!
Old 02-19-2012, 05:46 PM   #13
Tileguy
JazMan's Avatar
Well...not in the right order and you can not "pour" mud, but otherwise you seem to have the idea.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
almazon (02-20-2012)
Old 02-27-2012, 01:31 PM   #14
Jaz
Heya Jaz,
Guess what? I decided to go with SLC and describing my experience in SLC: Mixed Feelings thread.
almazon
PS. Sorry gbook2 for hilacking your thread. I hope you removed those tiles with no problem!
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 11:42 PM
Replacing Ceramic tile floor handy andy Flooring 4 03-28-2011 01:07 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Ceramic tile over asbestos tile question MLMIB Tiling, ceramics, marble 4 01-10-2011 08:58 PM
Water Damaged Ceramic Tile DoubleTrouble Flooring 4 06-12-2010 03:17 PM
