Old 02-16-2011, 12:35 AM   #1
HOw to remove Cement Board
I'm having a REALLY hard time getting sections of the cement board off of hte plywood sub floor. I got all the old tile up, but sections are nailed down with about 2" between nails, adn then it seams like it might even be glued down. Besides my VERY slow chisle and hammer method!?!?
eadamiec is offline   Reply With Quote
Old 02-16-2011, 12:36 AM   #2
Tileguy
Bud Cline's Avatar
Rent an electric chisel.
Old 02-16-2011, 01:24 AM   #3
Renovations contractor
Bonzai's Avatar
Sometimes it's far quicker just to pull up the plywood too and lay a new subfloor.
Home Renovations & Repairs
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 02-16-2011, 08:27 AM   #4
Tileguy
Bud Cline's Avatar
Are you sure you know what you are talking about?
Old 02-16-2011, 08:28 AM   #5
Tileguy
Bud Cline's Avatar
Wish I hadn't done that twice!
Old 02-16-2011, 12:02 PM   #6
I use a roofing shovel.
FlooringDude is offline   Reply With Quote
Old 02-16-2011, 09:47 PM   #7
I like the roofing shovel idea. Get a sturdy one.
elarreau is offline   Reply With Quote
Old 02-17-2011, 11:26 AM   #8
Bonzai's Avatar
Yes but thanks for asking. Notice I did say "sometimes". I am merely saying it is another option which I am sure the OP can determine if is viable or not depending on other factors.
Old 02-17-2011, 08:53 PM   #9
Tileguy
Bud Cline's Avatar
Bonzai: "Sometimes it's far quicker just to pull up the plywood too and lay a new subfloor."
Blindly advising someone to "pull up their subfloor" is bad advice on a DIY Internet forum. It doesn't matter whether or not you try to feather your comment by using the word "sometimes". Removing sub-floors is not routine and can effect the structure and get people that don't know any better in a helluva lot of trouble.
Just trying to keeps things as accurate as possible.
Tags
cement board, subfloor
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 09:29 PM
Cement board for crawlspace skirting? IfItAintBrokeFixItAnyway Building & Construction 12 09-29-2010 08:43 PM
Installation of Granite Tile On Shower Walls Spacing Question. taras1 Building & Construction 2 08-04-2010 12:48 PM
XPS foam board between basement slab and cement board for ceramic tiles jpsmith Flooring 4 02-10-2009 09:17 PM
cement board over brick fireplace wawrow General Discussion 2 11-21-2008 10:21 AM
