How To Refinish A Small Section Of Hardwood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 02:34 PM   #1
I have a 3/4" oak hardwood floor with a rug covering most of it. The floor is in excellent shape less an area about 2 square where there is a transition from one room to another and no rug. Here the finish has worn away completely.
Without redoing the whole 12x 14 floor (just not needed), how can I repair/refinish this area?
Thanks!
jdbs3 is offline   Reply With Quote
Old 06-15-2012, 07:59 PM   #2
Rewards Points: 14,026
Post a picture, there really is no great way except to refinish the worn floor.
If you really wan it to match hire this one out to a real hardwood floor refinisher.
Old 06-16-2012, 12:17 AM   #3
You can tape around the board(s) with painters tape, then lightly sand them with a 220 grit sand paper. Then wipe the area clean and apply a couple of coatings of whatever finish was used on the rest of the floor. If you are not sure you may need to test a couple different types.
RhodesHardwood is offline   Reply With Quote
Old 06-25-2012, 02:06 PM   #4
Here is a picture. you can see the good floor all around the rough area; it was covered by rug.
Does this change the suggestion made for refinishing this small area?
Thanks!
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 06:15 PM
Hardwood floor stripping problems cmdrico7812 Flooring 3 09-13-2011 10:58 PM
unique problem with hardwood floor seanbellay Flooring 15 05-02-2010 06:53 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
