-   -   How To Refinish A Small Section Of Hardwood Floor (http://www.diychatroom.com/f5/how-refinish-small-section-hardwood-floor-147142/)
jdbs3 06-15-2012 02:34 PM
I have a 3/4" oak hardwood floor with a rug covering most of it. The floor is in excellent shape less an area about 2 square where there is a transition from one room to another and no rug. Here the finish has worn away completely.
Without redoing the whole 12x 14 floor (just not needed), how can I repair/refinish this area?
Thanks!
joecaption 06-15-2012 07:59 PM
Post a picture, there really is no great way except to refinish the worn floor.
If you really wan it to match hire this one out to a real hardwood floor refinisher.
RhodesHardwood 06-16-2012 12:17 AM
You can tape around the board(s) with painters tape, then lightly sand them with a 220 grit sand paper. Then wipe the area clean and apply a couple of coatings of whatever finish was used on the rest of the floor. If you are not sure you may need to test a couple different types.
jdbs3 06-25-2012 02:06 PM
1 Attachment(s)
Here is a picture. you can see the good floor all around the rough area; it was covered by rug.
Does this change the suggestion made for refinishing this small area?
Thanks!
