How To Put In Vertical Parts On The Stairs - Flooring - DIY Chatroom Home Improvement Forum
Old 01-02-2007, 10:26 AM   #1
How to put in vertical parts on the stairs
My basement stairs only have the horizontal steps... it does not have the vertical plates.... I don't know how to name them... somthing like tread...etc... anyhow... here is what I think I am going to do to complete it, please let me know if there is wrong doing:
1. purchase those nice looking pine wood may be a inch thick woods from HD
2. cut them fit in the rectangular holes.. may be a bit bigger so that they can fit tight.
3. put glue on them before fitting
4. nail them besides gluing... my question here is whether I should use finish nails or nails with flat head? and do I need to nail from the top and bottom or just the top is enough, as I don't have a nail gun, nailing from bottom is quite hard especially the steps at the lower part of the stairs... or do I need nail at all, if the liquid nail is good enough...
thanks
KUIPORNG is offline   Reply With Quote
Old 01-02-2007, 01:11 PM   #2
riser boards.
How far do the treads protrude from the stringers?
redline is offline   Reply With Quote
Old 01-02-2007, 01:34 PM   #3
you probably asking is there enough room to put the riser on top of the tread at the end... I need to check this out...
Old 01-03-2007, 08:39 AM   #4
Did some measurements
the space allowed to put the risers on top of the tread is 3/4 inch. it is not a lot. I suppose I need to buy wood with such thickness for the riser, i.e. 3/4 inch. the tread's thickness is 1.5 inches. so do I need to nail the riser onto the tread? or liquid nails is good enough...
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 07:16 PM
Goodman Air Handler with Missing Parts cougarhsv HVAC 2 01-17-2007 08:14 PM
Railing on Stairs Melanie337 Carpentry 6 10-04-2006 09:39 AM
