-   -   how to put fall on hardi flooring (http://www.diychatroom.com/f5/how-put-fall-hardi-flooring-48431/)
bernster61 07-08-2009 08:29 PM
I am trying to put some fall on hardiflooring
It has to fall from both sides and both ends
The drain is in the centre
I want to put down the same vinyl that they use in hospitals
And i have to use a gattic drain
Pleas HELP
Bud Cline 07-09-2009 09:44 AM
Try again.
Floor slopes aren't built in that manner. What exactly are you trying to accomplish here?:) Where are you getting your information?:)
bernster61 07-09-2009 06:29 PM
Im trying to put in a shower in
I do not want to put in a base
I have taken out the hardwood floor and put down hardiflooring
Which is like thick cement sheet
Now i would like to form like a shower base on top
Then there is vinyl you can put on top
Bud Cline 07-09-2009 08:10 PM
You sound as if your mind is made up!:yes:
THAT would be a one of a kind home grown concoction that no one in the industry would condone.:no:
Sorry, can't help you with this one.:(
Now if you want to get serious and build a shower that will last beyond its first use say so and we'll try to help.:)
Scuba_Dave 07-09-2009 08:33 PM
Actually Hospitals do have non-slip vinyl shower floors
They weren't that good looking
But maybe somebody makes something in better colors/design
Bud Cline 07-09-2009 08:57 PM
Yes and they are coved and the copings are welded. Been there done that. I can promise you THAT isn't what bernster is up to.:)
GAR-AN-TEED!:)
bernster61 07-09-2009 10:12 PM
:)Yes that is exacyly what i want to do
Bud Cline 07-09-2009 10:18 PM
Do you have aluminum cove topping, wood chamfers, vinyl welding rod, and a vinyl welder?
Hardibacker board still isn't the way it is done.:)
bernster61 07-09-2009 10:40 PM
The vinyl layers have all the equipment to do the laying
These thinks aluminum cove topping, wood chamfers, i do not have
Originly i was ging to slope to one end and put in a stainless grate at one end but the vinyl people say i need to use a gattic drain
The flooring i have used is SYCON SECURA
