Old 10-31-2006, 08:57 AM   #1
Default How to put baseboards on curved walls
I'm not quite sure how to put baseboards onto curved walls. The baseboards I took off were wood with small cuts on the backside along with thin wire running in the board. I have about 30 ft run to do and I would like to use wooden baseboards. Any suggestions would help.
Oray is offline   Reply With Quote
Old 01-10-2007, 08:41 PM   #2
Tile and Paint contractor
i'm not a trim carpenter, so you should probably ask someone who is,
but we do do baseboard trim after installing tile
I would suggest relief cuts on back spaced tighter on transitions
nail off, and have someone knee push it closer as you go
scarf cut (45) where baseboard meets new piece
never had to do curved walls
don't understand concept of curved walls anyhow
Matt | tile contractor
Charlotte, NC
read my articles
MattCoops is offline   Reply With Quote
Old 01-23-2007, 10:39 AM   #3
go to home center and order flexible molding, once its painted looks identical to wood base
Savannah is offline   Reply With Quote
Old 01-26-2007, 02:50 PM   #4
Take a look at these threads on this fourm
http://discussdiy.com/showthread.php...stid=51#post51
http://discussdiy.com/showthread.php?t=150
Mgmopar
MgMopar is offline   Reply With Quote
More On This Topic
Okay, so our next step is to tape off our trim. We have decided that this little quarter inch molding we’re going to paint the same color as our walls and also our ceilings are going to be the same color as our walls. As Craig was explaining... Read More »
Painting Kitchen Walls
Painting Kitchen Walls by Expert Village
Moving right along. Our next step in painting the kitchen is going to be to cut in the wall area. We want to cut in the edges before we roll. So let me jump up on my ladder and let's begin. It's okay, we came a little bit over onto the trim. We're using... Read More »
Hi this is Jon on behalf of Expert Village, in this video clip I will show you how to make our straight trim for our top. For my top I need to make a piece of straight trim for both sides and the rest of the front that is going to tie in to this curve... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
Wallpaper in a dollhouse room is a great way to make the room look homey and lived in. It is also a great way to emphasize the period and style of the home. From a sweet checkered pattern in the baby room to an ornate velvet medallion print in the... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
