Old 01-01-2012, 09:39 AM   #1
How to properly acclimate oak flooring?
Happy New Year!
Tomorrow we are placing an order for 1,300 sq ft. of Shaw brand oak. It looks like it will be delivered to the house 7-10 days before we start the job.
The house is 30 y.o., as is the 3/4" plywood we are installing it on.
Should we take the wood out of the box to properly acclimate it? I would prefer not to, but will if it is necessary.
Any other precautions in this regard?
Thanks.
MurphyMan is offline   Reply With Quote
Old 01-01-2012, 11:25 AM   #2
Are you going to do the instal yourself, or will you hire it out? The reason I ask this is because of some technical processes that you will need to do before the instal. To CYOA. Moisture content of wood, then a humidor test for the house humidity levels. These need to be done before the instal. This way you have the Specs needed if you have any problems with Cupping, Warping with the manufacturer. Also if you have a basement, that to will need to be tested as well for humidity levels. 7-10 days to acclimatise seems to be on the minimal side to me. I am sure there are more knowledgeable that will chime in....................Good Luck To you...........
mark942 is offline   Reply With Quote
Old 01-01-2012, 11:39 AM   #3
Pro Flooring Installer
rusty baker's Avatar
Acclimation has nothing to do with time. It is moisture content, period. With that much invested, buy a moisture meter.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 01-01-2012, 05:07 PM   #4
Thank you. Yes, I am doing myself, and spending hours on this forum to make sure I get it right.
I see the point of getting the moisture meter and recording the initial moisture levels. I found one at Lowes for $29.95 and the reviews were good.
No basement - crawl space.
How to cut exhisting flooring in the doorway jjpar Flooring 8 10-26-2011 12:01 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 08:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 12:32 PM
