How To Prep Expansion Joint For Vct - Flooring - DIY Chatroom Home Improvement Forum
Old 10-26-2012, 11:14 PM   #1
Rewards Points: 616
how to prep expansion joint for vct
7 year old above ground slab do you fill with something like ardex or use something flexible to fill joint with before laying vct
also do you try to get joint of vct to land on a expansion joint
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is online now   Reply With Quote
Old 10-27-2012, 10:32 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Fill with something flexible like NP1. The VCT will probably crack regardless if you go over it. Ideally you need to place an expansion joint like Schluter Dilex in the surface of the tile as well.
Darkling Designs
poppameth is offline   Reply With Quote
The Following User Says Thank You to poppameth For This Useful Post:
jaydevries (10-27-2012)
Old 10-27-2012, 08:45 PM   #3
Rewards Points: 31
Expansion joints are not meant to be covered with flooring, hence expansion. You should stop the VCT at the expansion joint and then continue to lay the VCT on the other side leaving a gap for the slabs movement, you will then need to install a floor transition over the expansion joint to cover this gap. If it ends up that the VCT needs to be cut at same 3/4 of a tile, continue on the other side with the remaining 1/4 tile, this will make it seem as though there is a full tile. It will really depend on the slab and how much movement will take place but I would go ahead and cover over and if it does end up cracking at the joint you can always install a transition at that time.
Hardwood Head is offline   Reply With Quote
Goofy expansion joint question 614Brewer Landscaping & Lawn Care 2 06-09-2012 09:32 AM
Concrete Path Against Foundation without Expansion Joint Baoh Building & Construction 2 11-20-2011 04:14 AM
Expansion joint john4153 Plumbing 0 10-05-2011 08:51 PM
Tiling over expansion joint - confused jkr77 Flooring 20 04-12-2011 04:56 PM
expansion joint farrington135 Building & Construction 1 01-27-2006 11:02 PM
