How To Pick A Wood Stain? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-15-2009, 12:50 AM   #1
How to pick a wood stain?
So I'm Refinishing my original hardwood floors in my 1950's California house. I think It's red oak but I don't know the diff. between White and Red oak. Its 2 1/4" wide by 1/2" thick. I got it sanded and ready to stain, but I'm wondering if I test stain in a few areas how easy It would be to cover over it. This is a living room. There is no closet to test in. Nor is there really good hidden place to try it. I see some have done this.
If I try that how to I go about getting rid of the stain I don't want? Does the stain go deep? Is sanding it again the only way? what grit? I currently have MINWAX Red Mahogany 225 picked out, but I'm not sure how it would look in a whole room. Anyone have some pics of stained red oak? Thanks JIM
integlikewhoa is offline   Reply With Quote
Old 06-15-2009, 06:07 AM   #2
If you've still got the sander on site, go ahead & stain anywhere to pic a color, then run the sander back over the stained area with whatever final grit you sanded. If you don't still have the sander, you can use a belt sander with the same final grit paper. Don't sand smoother than the rest of the floor or it could potentially not stain the same as the rest. The stain is not going to go very deep at all.
One other thing, be sure to sand past & feather your sanding out so as not to create a noticable dip.
pinwheel45 is offline   Reply With Quote
Old 06-15-2009, 09:50 AM   #3
I don't still have the rental sander on site, but I do have a hand belt sander and a small corner cat (vibrating sander). I thought the stain went deep and was worried it would take a lot of material and feathering to get back to normal. Thanks JIM
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Stain is too dark on wood floor -- Can it be lightened? proofer Painting 8 09-06-2009 09:28 AM
Stain Brochures vs Wood Samples rjordan392 Painting 5 04-08-2009 05:28 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
