How To Patch Hardwood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-18-2013, 02:37 AM   #1
Rewards Points: 422
How to patch hardwood floor
We pulled up the carpet in a bedroom, and there's a plywood patch in the oak flooring, where closet opening is(there used to be sliding doors on closet). The problem is the patch runs perpendicular to the flooring boards. How do we repair this? The size is about 5" X 22". Thanks.
Jim McC is offline   Reply With Quote
Old 11-18-2013, 04:43 AM   #2
DIY staff
Rewards Points: 7,174
A couple of questions before you get an answer----
Are you going to refinish the floors?
Is this sanded in place flooring or modern prefinished?
Do the closet boards line up perfectly with the boards in the room?
What tools do you have?
Could you post a picture?
Old 11-18-2013, 05:12 PM   #3
Rewards Points: 422
1) Yes, in the spring
2) sanded in place, 3/4" oak hardwood from 1975
3) Yes
4) Circular saw, drill, chisels.
5) I cannot post a pic. The next time one of my kids comes home to visit, they can probably do it, but that may be weeks from now.
The current plywood patch encompasses 10 boards plus about 3/4" of the 11th one.
I see online how to replace a board, but I can't find one that shows a perpendicular patch like I have.
Old 11-18-2013, 05:38 PM   #4
DIY staff
It sounds like you will be 'lacing' in new boards---a table saw or router would be helpful but not essential--the back portion of the groove and maybe part of the tongue must be removed.
You will be removing boards back to the nearest joint---
-to do this--use your Skilsaw to cut out the center of the floor boards--leaving the tonge and the groove edges--
-chisel out what you have left--
-slip in a new board--remove the tongue or back of the groove as needed---
use Bostich hardwood floor glue or PL premium ---nail in the exposed tongue---
If the closet is small it would be easiest to remove that so you don't have to 'fill in the gap'--which requires some precision cuts---
A hardwood guy will be along soon----I think this is easier to do that to explain---Mike---
Old 11-18-2013, 08:33 PM   #5
Rewards Points: 422
Thanks Mike. If I'm understanding you, I need to replace all 10 boards, since the patch currently involves 10+ boards?
Old 11-19-2013, 04:42 PM   #6
Rewards Points: 422
Anyone ?
Old 11-19-2013, 04:53 PM   #7
DIY staff
I'm back---yes, if the closet is ten boards wide--then all ten need to be removed back to the nearest joint---
Old 11-19-2013, 05:00 PM   #8
DIY staff
▶ Palian wood floor repairs - YouTube
Old 11-19-2013, 11:38 PM   #9
Rewards Points: 422
Thanks Mike. I just watched another video on Youtube, where he replaced the T&G board with a straight edge board. Do you think that would be a mistake if I did that?
Old 11-20-2013, 05:28 AM   #10
DIY staff
If the repair won't look like a hasty repair, that would be a lot faster---
I have done several like that---circular saw--router and chisel --with thought and patience,the repair can be done nicely. A multi tool will be helpful.
Your tooling will be the big expense---nails might wreck a blade or bit---
Old 11-20-2013, 05:34 AM   #11
Look at the damaged flooring plank and decide how much length to remove. You want the new butt joint to be staggered about 10 in. from the butt joints of any adjacent flooring courses. Draw a line for the cut, then use a sharp chisel (1 in. or wider) to carefully cut the line through the top 1/8 in. of the flooring to create a crisp edge that defines the new butt joint.
bickeldan817 is offline   Reply With Quote
Old 11-20-2013, 12:49 PM   #12
Rewards Points: 422
Thanks guys. If I did use the straight edge method, do I just buy oak T&G flooring, then rip the tongue off? Or is it available with straight edges? My floor is the standard 2.25" oak T&G.
Old 11-20-2013, 04:31 PM   #13
DIY staff
If you are planning on insetting a piece across the doorway,perpendicular to the old flooring--I would suggest you use a solid red oak board, rather than strips of flooring--
Old 11-20-2013, 09:01 PM   #14
Rewards Points: 422
I meant removing pieces of 10 boards, and replacing them with straight edge oak boards. Or is that a bad idea due to the boards not interlocking together?
Old 11-20-2013, 09:24 PM   #15
DIY staff
By all means,use tongue and grove flooring--just remove the tonge or back of the groove where needed---
Hardwood Floor Buckling klappjack Flooring 6 10-04-2014 11:21 AM
Relocating floor HVAC register, how can I patch up the hardwood floor? htabbas Flooring 3 11-30-2011 07:53 AM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
unique problem with hardwood floor seanbellay Flooring 15 05-02-2010 06:53 PM
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 10:20 AM
