How To Patch Crack In Lineoleum? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-10-2010, 11:45 AM   #1
Rewards Points: 83
How to Patch Crack in Lineoleum?
My kitchen floor is sheet vinyl, and at one doorway there is a metal edging strip holding the sheet vinyl down, forming a downward crease in the sheet vinyl where it meets the hardwood floor in the adjacent room. After 12 years, a 1/8" crack has now developed in the crease, and it is already several inches long and rather visible. How can I patch this crack until I can replace the floor in a year (as part of an overall kitchen remodel)?
MrBill_DIY is offline   Reply With Quote
Old 04-10-2010, 12:26 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
If this is a piece of gold flat metal, you can just use a wider piece. It comes in 1", 1 1/2" and 3" .
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 04-10-2010, 04:02 PM   #3
Rewards Points: 83
The metal edging strip in the doorway is angled. On the lineoleum side, it's about 1/2" wide, and on the hardwood floor side it's 1" wide (the hardwood floor is lower than the linoleum). So maybe I could replace the edging strip with a wider one and just cover up the crack in the lineolum -- not a bad idea. Maybe I can find an angled edging strip that is 1" on both sides of the angle. I assume that I can just pry the edging strip up?
Crack in Cast-Iron Wye sonofthetonsured Plumbing 16 01-15-2010 08:10 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 09:14 PM
How to patch crack on brick wall ? anku Building & Construction 1 07-05-2009 09:30 AM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 01:07 PM
Floor patch HomeDepot23 Flooring 2 07-24-2008 07:03 AM
