How To Nail Base Cap Of Baseboard Molding - Flooring - DIY Chatroom Home Improvement Forum
Old 06-23-2010, 09:23 AM   #1
how to nail base cap of baseboard molding
I laid down a floating engineeried wood floor (over existing very old hardwood floor), and now need to install new basebaord molding. I've cut all the 1" x 7 1/4" pine boards and the separate base cap pieces (including the coped inside corners and mitered outside corners).
I seem to remember that when I pulled out the previous baseboards, the old base cap was nailed to the base boards, not the wall. Yet when I tried to put my first finishing nail vertically into the new base cap, it was about to split (so I pulled it out and pre-drilled the hole).
Should base cap be nailed to the base boards or into the wall? I couldn't find the answer anywhere on the internet.
conradA is offline   Reply With Quote
Old 06-23-2010, 09:45 AM   #2
Chicago, IL
Michael Thomas's Avatar
Should shoe molding (base show molding) be nailed to the base molding or the flooring
If you are referring to “shoe molding” (AKA “base shoe molding”), is should be nailed to the base, not the flooring:
This allows the floor to move inwards and outwards as the flooring expands and contracts in response to changes in humidity and temperature without buckling the floor or pulling the the shoe and/or base molding away form the wall.
_______________________________
BTW, don't know what profile you selected, but "base shoe" is not the same as "quarter round" - the difference seems subtle in profile, but to my eye the choice makes a surprisingly large difference in the finished appearance:
- http://www.woodfloorsonline.com/tech...-outlines2.gif
___________________
I’m paid to be suspicious…
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 06-23-2010, 10:02 AM   #3
This is not a shoe molding, it is the decorative base cap that goes on *top* of the baseboard.
Old 06-23-2010, 12:57 PM   #4
47_47's Avatar
Rewards Points: 44
All of the old base cap and baseboards I've seen, they are nailed together and only the baseboard is nailed to the wall.
47_47 is offline   Reply With Quote
Tags
base cap , baseboard , moldings
removing/replacing base molding on brittle plaster wall alt Remodeling 3 09-08-2009 10:28 PM
Painting baseboard molding same color as chair rail and crown molding Barb Wieczynski Painting 4 04-11-2009 09:32 AM
Help with adding a strip of molding over baseboard. Bobrobert Remodeling 15 01-15-2008 11:12 PM
going to make mirror frame/edges out of crown molding or baseboard - dumb idea? joeyboy Carpentry 6 11-12-2007 08:39 AM
Baseboard molding tiled in... Donald Lynskey General DIY Discussions 1 07-07-2007 07:47 PM
