How Much Thinset To Set Durarock - Flooring - DIY Chatroom Home Improvement Forum
Old 08-21-2011, 01:43 PM   #1
m1951mm's Avatar
How much thinset to set durarock
I am getting around to setting the durarock prior to ceramic installation on my bath. It has been torn out since 2004. I have 7.5 sheets of durarock and am wondering how much thinset I need to set them. I was told that the cheap thinset for this purpose is just fine????????? Any other hints would be greatly appreciated. What size trowel?? I am working over plywood where I pulled up old commercial style vinyl flooring and the black sticky stuff is still there. I was told that adheasion is not the issue with laying the durarock since it is screwed to the subfloor, it is a matter of getting a flat surface to lay to. Is this right?
How much thinset to set durarock-bath-floor-001.jpg   How much thinset to set durarock-bath-floor-002.jpg
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
Old 08-21-2011, 01:51 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Any "unmodified" thinset is fine for installing the cement board. Unmodified is the lowest cost thinset.
Use a square notched trowel 1/4" X 1/4" X 1/4". Then use fasteners in the schedule recommended by the cement board maker.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
m1951mm (08-21-2011)
Old 08-21-2011, 01:58 PM   #3
m1951mm's Avatar
Hi Bud, I should have known that you would be the first to respond So I am guessing that you see no problem with that stupid sticky black stuff? How many bags of thinset should I buy? 7.5 sheets
Mickey
Old 08-21-2011, 02:06 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Just happened to be in the neighborhood.
Nope, no problem.
You should bring home two bags. You are at 112 square feet and typically that would take two bags.
Don't forget you will need "seam tape" when the time comes to install the tile.
XXX
Old 08-21-2011, 02:10 PM   #5
m1951mm's Avatar
Thanks, Got the tape an know to do that when laying the tile>
You the Man!!!!!! Thanks Bud!
Mickey
The Following User Says Thank You to m1951mm For This Useful Post:
Bud Cline (08-21-2011)
Old 08-22-2011, 10:48 AM   #6
Tile with Style
BlueStoneFloors's Avatar
Good luck Mickey, make me proud Nice toilet cut! I don't think I could have done it better myself...
Brian
Hell is 8 months of nothing but slate work...
BlueStoneFloors is offline   Reply With Quote
White thinset and Gray Thinset, does it really make a difference.. yummy mummy Tiling, ceramics, marble 25 02-04-2012 12:00 AM
questions about thinset ponch37300 Flooring 16 03-16-2011 12:45 PM
Is thinset always necessary? 123 Tiling, ceramics, marble 2 04-29-2010 08:01 PM
Fortified Thinset poolecw Flooring 4 10-31-2008 08:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 04:51 PM
