How Much Thickness Will Thinset Add? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-21-2011, 10:07 PM   #1
How much thickness will thinset add?
I'm doing tile in our laundry and its going to meet the existing wood floor in our kitchen. If add a layer of thinset (to the ply sub-floor), then backer board, then another layer of thinset, then tile, how much thickness will those two layers of thinset add?
I'm trying to get the transition from the tile to the wood floor to be level as possible and am debating between using 1/2 inch and 1/4 inch backer.
Also, is there anything wrong with using 1/2 inch backer board (rather than 1/4) so I get the tile closer to the level of the wood floor the tile will transition to?
Cheers.
Kiwi.
Kiwi. is offline   Reply With Quote
Old 04-21-2011, 11:02 PM   #2
Rewards Points: 5,336
Cheers.
Kiwi.
What thickness of plywood is on the floor now? You need to increase the floors rigidity to keep the tile from cracking. That usually requires another layer of ply to get it up to at least 1".
Ron
Old 04-22-2011, 07:12 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 224
The thin set under the backer board may account for about 1/16". The bond coat for the tiles about 3/32 - 1/8". Your best bet is to use 1/4" which should end up being 5/16", standard thickness tiles can average about 3/8" installed, plus or minus. You'll be very close, but may need to tweak the last tiles a bit.
Although the more plywood the better, the industry minimum standard calls for 5/8" subfloor or thicker. 5/8" scares me, but 3/4" plywood subfloor has been proven for many years to work well as the subfloor for ceramic tile installations.
Have you consulted a span chart to see if your framing system is stiff enough for tile installation?
Jaz
JazMan is online now   Reply With Quote
White thinset and Gray Thinset, does it really make a difference.. yummy mummy Tiling, ceramics, marble 25 02-04-2012 12:00 AM
questions about thinset ponch37300 Flooring 16 03-16-2011 12:45 PM
thinset thickness for finished measurements? lifeisadimensio Flooring 3 03-02-2011 11:59 AM
Fortified Thinset poolecw Flooring 4 10-31-2008 08:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 04:51 PM
