How Much Overage To Calculate For Stairs? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-14-2009, 11:30 AM   #1
how much overage to calculate for stairs?
i'm doing a bunch of stairs with bullnose fronts and poplar risers. some are regular dimension stairs, and some are very odd angles.
do i use the standard 10% overage for them? i'm thinking it may be more.
thanks!
norcalsurfer1977 is offline   Reply With Quote
Old 01-14-2009, 12:51 PM   #2
Floorwizard's Avatar
15% will for sure get you there based on what you are saying.
If you give detailed info on the dimentions I would be happy to confirm a size if you like.
Floorwizard is offline   Reply With Quote
Old 01-14-2009, 10:41 PM   #3
thanks, floorwizard! i will take you up on your offer as soon as i measure them.
How to calculate joist spacing??? jayp Building & Construction 8 10-16-2014 07:12 PM
Heat Loss Gain how to calculate jufix HVAC 1 11-20-2007 02:46 PM
