How Much Carpet Do I Need? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-26-2010, 03:18 PM   #1
Rewards Points: 342
Question
How much carpet do I need?
I have an "L" shaped room with the following dimensions
20'6" (20.5) (length) X 12'2" (12.17) (width) and the smaller part of the room measures
13' (length) X 10'8" (10.67) (width)
I calculate that I need 426 sq ft. or 48 sq yd. Does this sound correct?
tripower is offline   Reply With Quote
Old 06-26-2010, 04:05 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 142
48 sq yd should give you plenty, without much waste. As long as there's no pattern.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 06-26-2010, 04:55 PM   #3
Rewards Points: 342
Question
That one width is actually 12' 1", how long are typical rolls? Are they EXACTLY 12' or are they a hair longer?
Old 06-26-2010, 05:20 PM   #4
Rewards Points: 142
Can be as wide as 12' 3" and as narrow as 11' 9". Usually around 11' 11", No way to know for sure. 48 yards should give you enough fill if it's not wide enough.
Old 06-27-2010, 10:58 AM   #5
Tileguy
JazMan's Avatar
Rewards Points: 410
You can request what minimum width you'll accept to cover that 12' 1". Ask the installer how much it'll stretch. As mentioned a 12' wide carpet can be as short as 11'9" and be "legal".
If it'll work you need less that you figured. 12x20.5' + 12x13' =12x33.5. Add a little for out of square and you need a 12x34' which is 45.33 sq. yds.
Jaz
Old 06-27-2010, 11:16 AM   #6
Rewards Points: 142
Sorry Jaz, but I don't know any retailer who would sell to you under those circumstances. If they have it in stock, they can just go measure it. If they have to order it in, they have no control over width and that is a small sale. No way they want to take a chance on getting stuck with special-order carpet. I have had my own store, you just don't tell a mill or distrbutor that you won't accept anything less than 12' wide. They would laugh at you.
bubble under carpet after water spill - fixing psittacus Flooring 4 03-06-2009 01:23 AM
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr chetsy Off Topic 9 12-03-2008 06:41 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
