Old 06-17-2009, 12:04 PM   #1
how to match two different type of flooring
I need some assistance with determining if it is possible to match flooring from two different manufacturers. Here is the problem. I got talked into purchasing Award flooring. I installed it in four 10 x 10 rooms and for the most part we have been satisfied with the product. last year we had water damage in one of the room and I had to remove about 1/3 of the flooring from one if the rooms. When I went back to the store to purchase replacement Award flooring, they said the did not carry the product anymore. I contacted award and was told they do not make it anymore. I have no desire to remove the remaining floor. Is it possible to match a new engineer floor with the existing award floor? The award was 86.5 in length, 7 inch wide, 1/2 inch thick. Thanks
cmacnulty is offline   Reply With Quote
Old 06-17-2009, 01:05 PM   #2
This isn't an answer, but have you contacted the manufacturer?
gma2rjc is offline   Reply With Quote
Old 06-17-2009, 02:18 PM   #3
Super Moderator
Floorwizard's Avatar
Not gonna happen.....
different click systems and thicknesses...
best to remove room and start new with a match or contrasting color
good luck
Time to ride again!
Floorwizard is offline   Reply With Quote
Old 06-19-2009, 04:36 PM   #4
I just had water damage in my home...I'm replacing it now (taking a break). My wife and I tried to match our floors, or find out who made it ours flooring so we could get an exact match. We wanted to avoid replacing the bedrooms and be close enough that a t-molding would break it up and not be noticible. We tried for a couple months and long story short we are replacing it ALL! It isn’t an easy task and I couldnt find anything that was close in color and thickness at the same time. You should be able to find something that is close to the other rooms in color/style but nothing is going to work with the same floor but that floor…your best bet would be to call the manufacture and see if anyone they supply still has it. Good Luck.
jstcruzin is offline   Reply With Quote
More On This Topic
How to Pick Ceiling Fans
How to Pick Ceiling Fans by Expert Village
Hello! My name is Adolph Ramirez from Tampa, Florida and on behalf of Expert Village, this is how to install a ceiling fan. Some of the things that you need to consider before selecting a new fan for your home are fan size height from the ceiling, blades... Read More »
You should select furniture making plans primarily on your skill level. Plans that are too complex or which require special equipment may only serve to frustrate you. Fortunately, furniture making plans and furniture "how-to" articles are widely... Read More »
Hi! My name is Steven from Keilholz Flooring on behalf of Expertvillage.com. In this clip I am going to show you how to measure for ceramic layout for your floor. This is a little bit tricky so pay attention. The fist thing you are going to do is you are... Read More »
Ergonomic furniture is all the rage in offices today. After paying out thousands of Workers Compensation suits that resulted from poorly made chairs and desks, businesses have embraced the newer ergonomic models. We should be doing the same thing in our... Read More »
Adding carpet to a dollhouse is a great way to make the room warm and cozy. Carpets can be found in an array of colors and styles, including plush, berber, printed, woven and hand-knotted. Whether a hand woven throw rug, an elaborate oriental rug or a... Read More »
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 10:00 AM
What type of grout and sealer is the best for flooring skullface Flooring 4 06-01-2009 11:00 PM
Need Help Flooring dont match? mrnewbie Flooring 3 10-10-2008 07:30 AM
what type of nail gun for bamboo flooring? matchley Flooring 4 12-26-2007 04:47 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
